How Important is the SplashShield
Old Aug 24, 2009 | 10:55 PM
dth0ng69's Avatar
Default How Important is the SplashShield
Okay So I have a 1998 Honda Civic Cx, and I just recently Installed a Cold Air Intake in my Civic, and it goes down pretty low So I didn't attempt to put the splash shield back on. Is the splash shield really important? I live in seattle.
thanks for reading any help suggestions feedback tips would be great.
Old Aug 24, 2009 | 11:56 PM
Arthas's Avatar
Default Re: How Important is the SplashShield
No its not really important but Honda put it there for a reason so just put it back on.
Plus, I like to think of it as a Mini-diffuser. It prevents air from hitting the bottom of your engine causing drag therefore giving you 10000 horse powers.
Old Aug 25, 2009 | 12:14 AM
yoej8's Avatar
I would push that intake filter further into the cai piping and then put the splash shield back. Imagine how much dirt is on that shield. Now imagine all that dirt/water going straight into the filter. my 2 cents
Old Aug 25, 2009 | 12:15 AM
erik_mullen's Avatar
Not that important
Old Aug 25, 2009 | 01:10 AM
trustdestruction's Avatar
This is kind of a no brainer...
Dirty filter = bad
wet filter = bad
splash shield = protection of filter from dirt and water
now think
Old Aug 25, 2009 | 07:23 AM
vtechjunkie's Avatar
If yo suck up water because you didn't want to re-install the splash shield; you could potentially hydro-lock you motor. You'd really be pissed then!
Old Aug 25, 2009 | 07:26 AM
92ehatch's Avatar
i didnt run a splash shield on my last car (dad threw it away while i had the motor out)
anyways, my engine bay was 10x dirtier without it. it was a pain to clean the bay out.
please put the shield back on
Old Aug 25, 2009 | 08:10 AM
dth0ng69's Avatar
okay judging from all you guys opinions, Im definatly going to put my splash shield back on, but allow me to justify why I didn't immediatly put it back on. The reason my Cold Air Intake goes down pretty low is because I don't have a bracket holding it up at the coupler, The reason I don't have a bracket holding it up is because the alarm siren is in the way of where the bracket is suppose to connect to the chassis. So I have to relocate the Alarm siren first.
Or I could just run a short ram... But that wouldnt be fun (as I just bought the Cold Air)
Old Aug 25, 2009 | 07:11 PM
dth0ng69's Avatar
okay so I got the spashshield back on without using a bracket. (I just lifted it up) only bad thing is that the radiator hose is touching the filter = warmer air... o well at least I'll have a cleaner bay/ filter...
Old Aug 25, 2009 | 08:43 PM
gen2tegboi's Avatar
I think I read somewhere that a CAI without the splash shield would cause the CAI to suffer from heat soak while stopped due to the heat of the asphalt.
Last edited by gen2tegboi; Aug 25, 2009 at 08:44 PM. Reason: oops didnt read the fact that you already put it back on
Old Aug 25, 2009 | 09:05 PM
Arthas's Avatar
..... FAIL..
I heard that intakes get heat soak from being real close to the engine, so lets remove them and not worry about it.
Old Aug 25, 2009 | 09:40 PM
gen2tegboi's Avatar
You mean Short Ram Intakes get Heat Soak from engine bay. CAI's advantage is that they do not suffer from this, however removal of the splash shield will cause heat soak.
Old Aug 27, 2009 | 07:58 AM
hmoobhero's Avatar
ok, lets clear this up a bit. the OP is talking bout the intake filter heat/splash shield. not the big rubber splash guard that goes under the car.
anyways, never had a CAI cuz it rains alot here and i hear horror stories but sucking in water so thats a no brainer. plus, i've always ran a comptech icebox.
Old Aug 27, 2009 | 10:11 AM
300whpej's Avatar
2 words:
zip-ties
Old Aug 27, 2009 | 11:22 AM
98civdx's Avatar
Master Detailer
because you live in seattle, i would just make it a short ram in the winter, and then throw it back on in the summer, and then just do your best to avoid the bigger puddles, when you have the full cia on
thats what got my gsr's, first motor
Old Aug 27, 2009 | 11:59 AM
I think you are mistaken.
Old Aug 27, 2009 | 12:35 PM
98civdx's Avatar
Master Detailer
[QUOTE=hmoobhero;39768115]ok, lets clear this up a bit. the OP is talking bout the intake filter heat/splash shield. not the big rubber splash guard that goes under the car.
QUOTE]
where does it say this??
Old Aug 27, 2009 | 12:44 PM
hmoobhero's Avatar
haha ok my bad, i am wrong. must of read it too fast. if thats the case i would put it back to be on the safe side. prob doesnt make any difference if off but on the plus side it helps protect the filter.
wcladman
Honda Civic (2006 - 2015)
May 24, 2017 07:23 AM
lmike6453
Jul 27, 2007 04:34 AM
Doom325
Apr 8, 2006 09:40 PM
Fuster_Cluck
May 23, 2003 03:39 PM
HoNdAeX11
Dec 24, 2001 09:23 AM
