need help with my radio harness
Old Aug 24, 2009 | 09:02 PM
S_K_C's Avatar
Default need help with my radio harness
ok so i am trying to install my pioneer head unit to my 92 eg and my constant and switch seem not be getting power to the head unit can someone help me
Old Aug 24, 2009 | 09:08 PM
Jackal6042's Avatar
Default Re: need help with my radio harness
What do you mean "seem" like they aren't getting power? Have you checked for voltage with a multimeter? Most 92-95 Civics I've done aftermarket radios on required the running of a new constant 12V wire. There are constant power ports on the under dash fuse box. Just use one of those female flat terminal connectors and some wire and you are golden.
Old Aug 24, 2009 | 11:04 PM
S_K_C's Avatar
o ok i kinda get it but can you kinda dumb that down for me...hehe are you saying i new a new constant wire? sorry new to this wiring stuff
Old Aug 25, 2009 | 07:08 AM
Yonick90's Avatar
i would suggest checking the wiring with the multimeter first like he said, no need to replace it then find out that wasnt the problem
Old Aug 25, 2009 | 01:10 PM
S_K_C's Avatar
ok thanks and i was also told thayt if im not getting enough power i could run it rom my fuse box in the engine bay is this correct?
Old Aug 25, 2009 | 01:24 PM
98civdx's Avatar
Master Detailer
check the fuse, it may be blown,
you can run a new wire form you battery, put a fuse in it, but everytime you shut the car off, it will lose all presets, and wont turn on when you start it.
Old Aug 25, 2009 | 02:39 PM
dk127's Avatar
There may be 2 fuses, one under the dash and one under the hood.
If he runs a new wire from the battery, why would he lose the presets? I have an Alpine I have hooked directly to the battery with no problem. The battery provides a constant source for power.
Old Aug 25, 2009 | 02:40 PM
dk127's Avatar
Check your fuses first. If your not getting enough power, you could just run a line from the battery, have an inline fuse, then wire it into the harness. You don't need to hook into the fuse box in the engine bay.
Old Aug 25, 2009 | 03:04 PM
grumblemarc's Avatar
The Grumpiest
Get an aftermarket harness.
Old Aug 26, 2009 | 12:27 AM
98civdx's Avatar
Master Detailer
crap, sorry had alot of crap on my mind,
he wont as long as the deck sees constant power form the deck. sorry if i confused anyone
Old Aug 26, 2009 | 12:28 AM
98civdx's Avatar
Master Detailer
nope,
his wires either dont have power or enough power, so how would a aftermarket harness help??
Old Aug 26, 2009 | 02:47 AM
The Grumpiest
Why don't his hot wires have enough power? I have used aftermarket harnesses for decades now and have NEVER had to splice into any wires and never had an issue with power.
tercelrcr
Audio / Security / Video
Oct 15, 2014 10:27 AM
willskillz805
Aug 7, 2009 05:16 PM
Pr-Type-R
Feb 6, 2008 01:21 PM
iplaybass
Jul 1, 2006 12:53 AM
O RLY
Nov 3, 2005 07:30 AM
