ABS Light?
Old Aug 24, 2009 | 08:56 PM
karrar55's Avatar
Default ABS Light?
my 93 honda accord needed its brakes changed(rotors, pads) and at the time the abs light turned on so I changed the brakes and the light is still on! what should I do? help would be appreciated! thanks!!!
Old Aug 25, 2009 | 03:02 AM
djkurious's Avatar
Default Re: ABS Light?
Check the fluid in the ABS tank. May need to add more.
Old Aug 25, 2009 | 03:57 AM
strengthisselfcontrol's Avatar
i have a similar problem. we recently bought a 96 accord and on the drive home, the brakes werent that firm so you would have to push the pedal down about halfway in order to start to stop. My dad checked the brakes and saw that the pads were pretty much new so he bled the brakes and now we can't get pressure back to the brakes. if i wanna stop the car, i have to push the pedal down all theway. throughout all of this the ABS light has been on. we checked the brake fluid levels in the cylinder but is there a separate cylinder for ABS fluid?
thanks
Old Aug 25, 2009 | 08:47 AM
TOAB's Avatar
thanks
Drivers side, toward the front, along the fender. I think 5th gens have a red cap on the reservoir
Old Aug 25, 2009 | 11:53 PM
karrar55's Avatar
I checked the reservoir and it was low. ima put more brake fluid tommorow. is their more steps to do after i put the fluid or do i just fill the reservoir and the light turns off?
Old Aug 26, 2009 | 05:19 AM
TOAB's Avatar
If it's simply due to low fluid, I'd think it just trips a dummy switch when low.
Old Aug 26, 2009 | 03:42 PM
karrar55's Avatar
o never mind the reservoir was fine!! i think i have to clean the sensors
Old Aug 27, 2009 | 08:07 AM
chofmann79's Avatar
Is there any way you could check the ABS error code? On my 94 accord, there is a blue 2-pin connector just underneath the glove box...jump the plug with a paper clip, then turn the key to ON. The light should come on for a few seconds, then turn off...then you'll get a series of blinking lights that tell you exactly what the problem is. You just have to count the number of blinks (each code is a set of two numbers...for example, it might blink 4 times, then pause 1 second, then blink 8 times....this would be error code 4-8, corresponding to the left rear wheel sensor).
It's a lot easier to just get the code, rather than trying to guess what might be wrong.
Old Aug 27, 2009 | 09:44 AM
shadowspace's Avatar
New User
its ur abs sensor on the wheel went out its 2 bolts and a wire but u got to find out witch one with a computer and order it from a dealer cost like 175 per 1
mfrs
Sep 5, 2015 12:32 PM
janv49
Nov 6, 2013 09:26 AM
norcalB18
Sep 12, 2009 07:06 AM
Komakazi_830
Aug 5, 2008 10:38 AM
raavango
Sep 3, 2004 03:31 AM
