Sheet Metal Tags / Punch?
Old Aug 24, 2009 | 12:26 PM
Agtronic's Avatar
Default Sheet Metal Tags / Punch?
Hey guys,
I need these done ASAP, and I just can't find anyone to do it. I've got alot of people telling me "no problem" and I end up waiting weeks for a quote, and so far I haven't heard a single price from anyone.
I need 100-200 of these little tags made, of 1/16" stainless. I know a few guys who can CNC them, but I need them punched because of the detail.
Overall dimension is ~3 x 1.5" ...
Old Aug 24, 2009 | 01:54 PM
dave@passenger's Avatar
Default Re: Sheet Metal Tags / Punch?
If you want them punched for only 100-200 pcs your nuts. The die will cost more than the material and 200 pcs. You want these parts waterjet, or laser cut with an inert table. Careful sending out drawings if you don't own solidworks, you might end up owning it.
Old Aug 24, 2009 | 02:42 PM
Agtronic's Avatar
How detailed can you go with these processes? I showed a few guys what I wanted to do and they told me to have it punched ...
Old Aug 24, 2009 | 02:52 PM
Stachi's Avatar
I agree, should be laser cut or water jetted. A Punch and Die is to expensive for those small numbers.
Marc
Old Aug 24, 2009 | 02:53 PM
ROTARY's Avatar
they are wrong!!
try this place. http://www.vintagelaser.com/index.html
Old Aug 24, 2009 | 03:06 PM
Agtronic's Avatar
Okay, can anyone do them? Anyone know someone who can do them?
Old Aug 24, 2009 | 03:21 PM
intense4thgen's Avatar
i work at a laser cutting shop and ive seen some small intrakit **** made up should be no problems send me a pm and ill see what i can do for you i know for sure if you have the dfx file it will save you lots
Old Aug 24, 2009 | 03:29 PM
BMCRace's Avatar
http://ghdiv.com/
They can do it
Tell them I sent you
I used to do the programming on their robot welder, they are capable of flywheel break punching you about 10,000 per day or they can do a small order for the lasers as well
-James
Old Aug 24, 2009 | 03:41 PM
Agtronic's Avatar
Thanks guys!!
Old Aug 24, 2009 | 04:47 PM
weiRtech's Avatar
OG Fabricator
markku, just email me a dxf or dwg and i can do them.
the only thing you have to keep in mind is that you cannot make a hole in the material that is smaller in diameter or thinner than the thickness of the material being used. something like that might have to be done in 22 gauge. i can have them done the day you send me the file if you need.
aaron
Old Sep 3, 2009 | 04:37 AM
ROTARY's Avatar
Markku did you get the tags made?
Old Sep 3, 2009 | 07:22 AM
Agtronic's Avatar
Not yet no ... I will definitely update the thread once I do.
Old Sep 3, 2009 | 04:44 PM
laydoutjimmy's Avatar
email kyle@guiltybydesign.net he runs guiltybydesign.net they do some sick work
Old Sep 4, 2009 | 11:18 AM
chrisbmx68's Avatar
anyone with an EDM could do those as well
Boner_Ben
May 26, 2009 06:53 PM
OceanStateTuning
Mar 21, 2007 10:47 AM
L-B racing
Nov 1, 2003 02:27 AM
jspecimports
Oct 23, 2001 02:41 PM
