4x100 Wheel adapters help
I picked up some BBS ra wheels for my civic but when Id mount them it only exposed like 1-2 threads of the wheel stud. Which means I need to get some extended studs.
I can replace my all my studs but its a PITA. So I was wondering if they sell some wheel adapters 4x100(5mm-10mm max)with extended studs
my buddy had the same problem. i took him to a machine shop and had the holes drilled deeper. if you choose to get extended studs then you will need to use the same seated lug nut as what is on the ra.
i think they were ol skool bbs from a bmw iirc
rice h8r
Apr 9, 2011 02:24 PM
