1992 honda accord ex transmission problem
Old Aug 23, 2009 | 06:37 PM
strumfetica's Avatar
New User
Default 1992 honda accord ex transmission problem
Hi,
I have 1992 automatic Honda accord EX.
The problem with it is that it harshly starts, and I think it's always in a 3rd or 4th gear. D4 light blinks all the time. I am driving it by manually changing the gears. When I change from 1st to 2nd, no rpm change, but when I change from 2nd to 3rd, rpm drops. From 3rd to 4th no rpm drop. The error codes I get when I troubleshoot it are 2 and 8, and ABS code is 31. I did solenoid check (while still mounted) by connecting it's terminal to + of the battery, and it clicked, when I connected both A and/or B terminal. I didn't check the TCU for bad capacitors yet nor wiring. Can you help me diagnose what's wrong??
Thanks and cheers
Ivan
Old Aug 23, 2009 | 07:48 PM
P_Adams's Avatar
Default Re: 1992 honda accord ex transmission problem
Originally Posted by strumfetica
Hi,
Thanks and cheers
Ivan
You might find this interesting.
http://techauto.awardspace.com/transmission.html
P
Old Aug 23, 2009 | 08:01 PM
New User
Thanks very much,
I reviewed this page couple days ago and I'm trying to follow the instructions from there. That is how I checked solenoids and pulled up the error codes from TCU.
I hope I'll have some progress with this.
Thanks and Cheers
Ivan
Old Aug 23, 2009 | 09:53 PM
New User
Does anyone have computer diagram for 1992 honda accord ex automatic. I want to rebuild it, by replacing it's components.
Thanks and cheers
Ivan
Chris Mason13
Jun 18, 2017 05:49 PM
2002accordguy
Nov 30, 2015 04:57 PM
hwright
May 15, 2013 03:50 PM
sherwo_od
Nov 21, 2010 02:29 AM
kercha83
Jun 4, 2008 09:45 PM
