2000 accord LX running hot question
Old Aug 23, 2009 | 04:35 PM
civicsi24's Avatar
Default 2000 accord LX running hot question
Hey all,
New here but not new to honda's at all. Here is a question for you that I cannot figure out. Couple months ago, timing belt snapped and......Well you know, so I just bought a used complete engine and replaced everything on it, all belts, water pump, thermostat, etc. So here we are now and the car is running pretty hot but the temp gauge is not moving out of the range it is supposed to be on the cluster. At normal operating temp, you can barely hold the upper radiator hose for a quick second cause it is so hot. Then lower is hot but not as hot. Spark plugs were white from running hot, which leads me to believe that the thermostat is stuck open? Anything else that it can be?
Harry
Old Aug 23, 2009 | 09:13 PM
alkoholikwun's Avatar
Default Re: 2000 accord LX running hot question
thermostat replacement is cheap and easy, i'd do that first then see if the issue goes away. good luck
Old Aug 24, 2009 | 12:01 PM
civicsi24's Avatar
Yeah I think it's the T-stat. I didn't buy a t-stat from honda so I am going there tomorrow and will throw the new one in. Thanks
Harry
Old Aug 25, 2009 | 07:15 AM
Heat's Avatar
Originally Posted by civicsi24
... Couple months ago, timing belt snapped ...
How many miles on the Accord when the belt snapped?
Just trying to get an idea of how durable those things are, my '99 LX has right at 100,000 miles on it.
Old Aug 25, 2009 | 07:25 AM
civicsi24's Avatar
I was pushing the limits at 135,000. The belt literally shred to pieces. Honda says to replace it at 105,000. Just make sure you also do water pump, thermostat, and possibly new belts while your there. GL
Harry
Old Aug 25, 2009 | 07:47 AM
cd5_801's Avatar
iv heard of the belts lasting up to 125000
Old Aug 25, 2009 | 09:34 AM
philadd's Avatar
Have you checked for air trapped in the cooling system?
Do both fans run?
Old Aug 25, 2009 | 11:32 AM
Janet@bisimoto's Avatar
Did you replace the t-stat? And if so what was the result?
Old Aug 26, 2009 | 03:05 PM
KaiKasei's Avatar
maybe your car is running too lean which makes the car run hot tryin to save gas makes the motor hotter so maybe check your fuel pump and the fuel filter
Old Aug 26, 2009 | 05:27 PM
civicsi24's Avatar
Sorry been very busy. I did not change the stat out yet, prob this weekend and I thought about the engine running lean (air/fuel gauge would be sweet) and will check the fuel pump since that is also very accessable also. Thanks for the help and will update soon.
Harry
Rsimmons618
Honda Civic (2001 - 2005)
Jun 12, 2018 12:31 PM
shoprag
Sep 12, 2010 12:27 PM
briluke
Jul 8, 2008 05:33 PM
Utilitarian
Sep 14, 2007 11:20 AM
