idle goes up, down, up, down etc on my b16
Old Aug 26, 2002 | 08:10 AM
red civic standard's Avatar
Default idle goes up, down, up, down etc on my b16
b16 in 91 civic standard
idles at 3000 rpm when the motor is started.
jumps from 800 rpm to 1500 to 800 to 1500 etc when it is warm. it sounds like i keep revving it up.
is this a vacuum line problem? fuel problem?
Old Aug 26, 2002 | 08:18 AM
E-AT_me's Avatar
Default Re: idle goes up, down, up, down etc on my b16 (red civic standard)
check vaccuum lines and coolant..
Old Aug 26, 2002 | 08:22 AM
Mr Furball's Avatar
Default Re: idle goes up, down, up, down etc on my b16 (Rexman)
check your TPS and make sure all vacume lines are where they are supposed to be. You might want to just get a new TPS and if that dosen't work just take it back.
good luck
Old Aug 26, 2002 | 08:34 AM
Doctor CorteZ's Avatar
check the TPS voltage
idle specs under .5 volts
check the IACV
check vacuum lines
any MIL codes ???????
Old Aug 26, 2002 | 09:17 AM
Default Re: idle goes up, down, up, down etc on my b16 (Doctor CorteZ)
no codes.....
i have heard of people cleaning their IACV to help their idle. anyone ever do this.
Old Aug 26, 2002 | 09:23 AM
SuperCivic's Avatar
yeah..that might be it..also check the fast idle valve..sometimes they get stuck.
Old Aug 26, 2002 | 12:15 PM
Default Re: idle goes up, down, up, down etc on my b16 (SuperCivic)
does a first gen b16 have a fast idle valve?
Old Aug 26, 2002 | 12:25 PM
Urban Business
Guest
Posts: n/a
my car does the same ****. only problem i can think of in my situation is this:
coolant temp sensor
guage cluster. si trans, i dont think the speed sensor in the stock cluster is calibrated to that of the si trans's speed sensor
Old Aug 26, 2002 | 12:29 PM
NikoZai's Avatar
no codes.....
no codes?!? what ECU are you using?
Old Aug 26, 2002 | 12:55 PM
Default Re: idle goes up, down, up, down etc on my b16 (NikoZai)
PR3 ecu
Old Aug 26, 2002 | 02:24 PM
Stinkalope's Avatar
New User
I cleaned my iacv valve twice, it helps for about a month. First narrow it down to make sure its that, then go buy a new one.
Old Aug 26, 2002 | 05:31 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: idle goes up, down, up, down etc on my b16 (Stinkalope)
For some weird reason, JDM B16's have the most gummed up IACVs of all Honda engines I mess with.
I think a new IACV should be in the parts list for a JDM B16 swap, right up there with a new timing belt and water pump.
Get one from a 90-93 integra or 88-91 CRX/Civic.
Old Aug 26, 2002 | 06:30 PM
Default Re: idle goes up, down, up, down etc on my b16 (Spaceballs the lunch box)
is the b16 IACV the same as the IACV from any 88-91 civic/crx motor?
is this for sure the problem?
Old Aug 27, 2002 | 06:29 AM
HybridFiend's Avatar
I don't know about the 88-91 civic, but the 90-93 Integra LS IACV works!
Old Aug 27, 2002 | 05:03 PM
No Big Whoop
Default Re: idle goes up, down, up, down etc on my b16 (HybridFiend)
It's the same except the ones in CRX DX or Civic standard.
If the engine is a DPFI, you cannot use it.
Get the IACV from any 90-93 integra.
Or a 88-91 CRX HF or Si.
or 88-91 Civic Si or EX.
And yes, a new IACV will fix your idle problem, provided you don't have any vacuum leaks.
Old Aug 27, 2002 | 05:57 PM
i replaced the IACV with one from a 91 d16a6...didn't fix the problem...i also cleaned up the pcv valve.
same problem....start the car and it idles at 3000, then when it warms up just goes back and forth between 800 and 1500...
any other ideas? please, this makes me not want to drive my car.
o2 sensors? tps?
Old Aug 28, 2002 | 01:42 AM
k4ff1n3's Avatar
check your map sensor and your vac lines.... that fixed ti for me.....
[Modified by k4ff1n3, 5:43 AM 8/28/2002]
Old Aug 28, 2002 | 02:00 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: idle goes up, down, up, down etc on my b16 (k4ff1n3)
it's the TPS.
Old Aug 28, 2002 | 04:34 PM
Default Re: idle goes up, down, up, down etc on my b16 (two.oh)
crxhfi, you are the ****.
took the intake off and halfway plugged the fast idle valve hole and the idle evened out...took off the metal plate and there was the plastic thingy all unscrewed...screwed it back in (had to push hard) and now the idle is PERFECT.
problem is I forgot to put the metal plate back on and when i went for a drive it flew out of my engine bay and i couldn't find it.
is there a fast idle valve plate on the d16a6? is it the same as the b16? i just need the metal plate and the two 8 mm bolts.
Old Aug 28, 2002 | 04:41 PM
Hondasaurs's Avatar
There is a flat head screw on your throttle body. It faces the passanger side of the car. Try adjusting this screw then reset your ECU. I had the same problem last week. This fixed it.
Old Sep 16, 2002 | 12:37 PM
chirp2hrd's Avatar
Default Re: idle goes up, down, up, down etc on my b16 (crxhfi)
does the vtec still work if the idle is messed up??
Old Sep 16, 2002 | 02:02 PM
.nate's Avatar
turn it in as tight as you can by hand...then replace the metal cover.
The actual procedure (this came from a friend who is a mechanic at honda) is to screw the IAVC screw all the way in, then back it off 2 1/2 turns.
Old Sep 19, 2002 | 09:56 AM
JDM88EF9's Avatar
Can this still work for my D15B2?
Old Sep 19, 2002 | 10:00 AM
Urban Business
Guest
Posts: n/a
Default Re: idle goes up, down, up, down etc on my b16 (N8-T)
that actuall precedure is wrong. unplug evac (iacv) then adjust to desired rpm. do this when car is warm ie fans has turned on
Old Sep 19, 2002 | 10:48 AM
ThatRicerDaniel's Avatar
its eacv .
