88-89 hf weight difference
1988 (lb/kg) 1819/826
1989 (lb/kg) 1834/851
I thought these were identical cars, 15 lbs is something.
They both have door mounting seat belts and no side impact beams in doors, or so i thought. I couldnt find any answer in the crx weight differences thread or in the faq.
I thought only the 90-91 models had door mounted seatbelts? Also, the weights shown say that there is a 25kg difference between the cars, which is 55lb's.
826kg = 1821lbs
851kg = 1876lbs
the sales brochure for the 1988 CRX does say that the HF weighs 1819lbs
the 89 model has different rear suspension from the 88 model
Yes my fault a typo, all 88s and 89 hfs have pillar mounted. Not door. I know.
So what is the weight difference?
I see people saying 89 hfs are the lightest, but it doesn't make any sence to me
??my 88 crx hf has door mounted belts??...I'll check the vin, maybe something's not right with this $200 shell???? good luck
90 doors (seat belt doors) cannot fit in a 88 chassis. it simply wont work.
you can put 88 doors on a 90 because there is more room for it.
joe, your car is NOT an 88.
Maybe the the vin has been swapped, but the car has clean title????
SpoonFed
Mar 19, 2003 08:34 PM
Steve91
May 21, 2002 06:10 PM
chasrex
May 16, 2002 01:53 PM
allmotorEG-SI
Sep 30, 2001 12:43 AM
