difference between vtec switchover & vtec engagement
Old Aug 23, 2009 | 03:25 PM
94civiccupew/b7's Avatar
Default difference between vtec switchover & vtec engagement
sorry if it's a dumb question, but I tried searching and found nothing explaining the difference between the two. i have a eg with a gsr swap and read that the switchover is at 4500 and engagement is at 5800. i know that the engagement is when it switches to the vtec lobe, but at 4500 is when i notice the motor gets louder as if it switched then. so i just wanted to get some clarity about this. by the way i just got the swap so understanding vtec is a little new. thanks
Old Aug 23, 2009 | 03:50 PM
Anton LaVey's Avatar
Default Re: difference between vtec switchover & vtec engagement
a gsr has secondaries and vtec
Old Aug 23, 2009 | 03:54 PM
Arthas's Avatar
Does the butterfly manifold have anything to do with it getting louder?
Old Aug 23, 2009 | 04:09 PM
omiehomie's Avatar
gsr has a dual stage intake manifold with butterfly's that open and close depending upon the rpm the motor is at...
Old Aug 23, 2009 | 04:26 PM
Murk 'EM's Avatar
yes it will get "louder" because the manifold is opening the secondary runners their for the engine is getting more air and their for getting more fuel there for being louder because more in = more out
Old Aug 23, 2009 | 05:25 PM
Arthas's Avatar
There you go OP, blame it on your manifold lol.
Old Aug 23, 2009 | 06:32 PM
oh yeah btw i have a skunk2 mani on it. so i don't have secondary butterflys
Old Aug 23, 2009 | 06:51 PM
but that doesn't explain the difference between the crossover and engagement
Old Aug 23, 2009 | 07:37 PM
bigD's Avatar
I dont know what your asking vtec crossover and vtec engagement are the same thing, think your getting secondaries mixed up with vtec.
Old Aug 23, 2009 | 07:45 PM
B18C1
  • VTEC (Dual Stage Intake Manifold)
  • Found in :
    • 1994-2001 Acura Integra GS-R (DC2)
      • Power : 170 hp (127 kW) @ 7100 rpm & 128 ft·lbf (173 N·m) @ 6200 rpm
      • Redline : 9000 rpm (limiter @ 8500 rpm)
      • VTEC Switchover : 4400 rpm <-------- that
      • Intake Manifold Switchover : 5750 rpm
      • Displacement : 1797 cc
      • Compression : 10:1
      • Bore : 81
      • Stroke : 87.2 mm
      • Rod Length : 137.9 mm
      • Rod/Stroke : 1.58
      • Transmission: s80
      • VTEC Engagement: 5800 Rpm <-------- that that's what i'm talking about
Old Aug 23, 2009 | 07:54 PM
bigD's Avatar
the 5800 is your secondaries it has nothing to do with vtec
Old Aug 23, 2009 | 07:59 PM
Arthas's Avatar
How does a GSR redline at 8500, yet max power is at 7100?
Old Aug 23, 2009 | 08:00 PM
so you mean to tell me that my vtec engages at 4400 when a type r engages at 6000? i don't think so
Old Aug 23, 2009 | 08:01 PM
you tell me i got these specs off the b series engine specs link on the faqs page
Old Aug 23, 2009 | 08:12 PM
bigD's Avatar
yes thats correct whats the problem.
Old Aug 23, 2009 | 08:13 PM
bigD's Avatar
lost of cars will hit peak power before redline
Old Aug 25, 2009 | 01:02 PM
bump for confirmation on bigD's theory
Old Aug 25, 2009 | 05:09 PM
B16AGUY's Avatar
He's right... many cars hit peak hp before redline.
Hell even many built civics that can redline at 10k hit peak hp at 8.5 to 9 k.
Old Feb 7, 2010 | 09:31 PM
mct121's Avatar
Icon2 Re: difference between vtec switchover & vtec engagement
Reviving an old thread because the question in the original post was never answered. I have seen this as well and am wondering the same thing. "VTEC Switchover" vs "VTEC Engagement."
I know this is a lot to ask, but can we keep the responses on topic?
Old Feb 7, 2010 | 09:50 PM
skaternak's Avatar
4000 is the secondary lobes. under that is primary lobes (smaller than secondary) thats why its louder when you get to 4000. and 5800 is the loudest (vtec lobe)
Old Feb 8, 2010 | 07:22 PM
mct121's Avatar
In the B18C1 I am pretty sure that there are only two cam profiles, the low profile lobes that are used when VTEC is not engaged and teh high profile lobes that are used when VTEC is engaged. So I am not quite sure what you mean by "secondary lobes," "primary lobes," and "VTEC lobes."
I am starting to think that nobody knows the answer to this question. :-p
goblynn93
24
Jan 29, 2012 12:14 AM
madblkscientist
Aug 14, 2009 09:00 PM
honda_lemus541
May 26, 2008 05:43 PM
type-GGSR
Apr 3, 2008 11:31 AM
GsRwHiTe
Feb 15, 2004 03:01 PM
