Skunk2 Camber Kits - Ball Joint Information
Old Aug 26, 2002 | 08:01 AM
EE_Chris's Avatar
Default Skunk2 Camber Kits - Ball Joint Information
I was looking into buying a set of these for my car [99 Cx hatch], however, I wanted to know about the ball joints.....specifically, if/when I needed to replace them, how could I.
After getting off the phone with Skunk2, I have this information for you guys:
1). The ball joints used are held in by a C-clip, so they are replaceable.
2). Skunk2 does NOT currently have any of these ball joints in stock and do NOT know when they are going to get some.
3). They do NOT know of an aftermarket replacement, as of yet, and do not know when they will find one.
What does this mean? If you own a set, and need to replace the ball joint, your S.O.L. for the time being. The tech didn't even have a rough guesstimate as to when a replacement would be found.
Note: The lower ball joint from a Honda will NOT work, according to the tech.
Old Aug 26, 2002 | 12:07 PM
CHEETAH's Avatar
Default Re: Skunk2 Camber Kits - Ball Joint Information (EE_Chris)
its supply and deman, no demand for balljoints so why should skunk2 spend money to produce batches of that ... either way, I think there is a 84 pontica sunbird balljoint that you can fit into the camber kit....
greg
Old Aug 26, 2002 | 12:16 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Skunk2 Camber Kits - Ball Joint Information (CHEETAH)
Junk2 does not manufacturer ball joints. I'm 100% sure they buy them from some other company. The question is, who?
I'll be so happy if I can get rid of this crappy camber kit.
Warren
Old Aug 26, 2002 | 01:50 PM
EXtasy's Avatar
i just got some from ingalls for my 93.
http://www.ingallseng.com look under poly products.
vanny_david
Suspension & Brakes
10
Nov 20, 2009 09:39 AM
hyrev20
Apr 7, 2009 04:47 PM
4drRacer
Oct 12, 2003 09:55 PM
EE_Chris
43
Sep 17, 2002 05:10 PM
EE_Chris
Aug 26, 2002 03:28 PM
