hose from intake to head
Old Aug 23, 2009 | 08:41 AM
project91crxsi's Avatar
Default hose from intake to head
when i got my car it came with a 3 way connector on the hose that goes from the intake to the head, alittle bit of air comes out of it when running, its a d16y7, should this be here? or is this whats causing my problems.
http://s98.photobucket.com/albums/l2...7091646-00.jpg
bottom left in picture
http://i98.photobucket.com/albums/l2...2091649-00.jpg
Old Aug 23, 2009 | 08:56 AM
njn63's Avatar
Default Re: hose from intake to head
Nope.
Old Aug 23, 2009 | 08:59 AM
~Logik~'s Avatar
Do you have a leak in that hose somewhere? if so..change it..
Old Aug 23, 2009 | 10:09 AM
i bought a peice of straight hose and put it on there and no CEL but still doesnt run right, and yes there was a hole in the hose so i just put on a straight peice of hose instead of adding that connector
Old Aug 23, 2009 | 12:17 PM
Gunmetal_B20_Hatch's Avatar
Originally Posted by project91crxsi
i bought a peice of straight hose and put it on there and no CEL but still doesnt run right, and yes there was a hole in the house so i just put on a straight peice of hose instead of adding that connector
check fuel pressure to make sure that the regulator is adjusted right, and what ECU are you using?
Old Aug 23, 2009 | 04:32 PM
the fuel pressure is around 35 psi when running, and im the ecu is a pm6 from a crx si
gursh d
Aug 21, 2007 08:35 AM
GetawayInMoscow
Jul 25, 2007 08:09 PM
Nikoli
Oct 26, 2004 02:40 PM
Andrew 825SM
Oct 28, 2002 02:31 PM
