Cut in-car heat from cat?
Old Aug 22, 2009 | 11:01 PM
DomGS-R's Avatar
Icon2 Cut in-car heat from cat?
I was wondering if this product would be good to stick under the car the cut the heat coming in the car from my 3'' metal cat? I feel a lot of heat from the shifter boot and on my right leg... and it raises the in-car temperature a lot...
http://www.thermotec.com/adhesive-ba...t-barrier.html
Will it peel off over time?
Or should I try to fit a heat shield on my cat?
Thanks for your time!
Old Aug 23, 2009 | 03:20 AM
IN VTEC's Avatar
Default Re: Cut in-car heat from cat?
I don't know if the adhesive is temperature stable to the temps for that area, but if it gets soaked with oil, it'll lose its tack.
Heat shield would be better or wrap/coat the exhaust.
Old Aug 23, 2009 | 02:30 PM
DomGS-R's Avatar
Thanks for your reply but do wrapping the cat will cause damage to it? Will it ''melts'' the inside?
This is the cat I use:
http://www.metalcat.com.au/
JDMEK9R
Jan 9, 2008 10:58 AM
yohan
Aug 31, 2004 12:43 PM
ggangtong81
Oct 2, 2003 03:31 AM
onyx00
Jul 21, 2002 06:38 PM
Maengelito
Apr 10, 2002 06:41 PM
