DOHC ZC OBD1 Conversion?
So, I am rebuilding a ZC right now... I was wondering if anyone has ever converted it to OBD1. Would this be worth it at all? Making it run smoother etc. I could source the parts from a newer D16, like the dizzy and O2 sensor, but what ECU would I use?
you would need the OBD1 DOHC ZC distributor, TD43U
unless you are going to boost the engine, converting to OBD1 has no advantage over OBD0 - it will run the same
^from my experience, the ls dizzy does not fit.
i'm using a 92-95 civic dx/lx distributor. you would really have to hack the **** out of it to get the timing "right".
for the ecu, get a p06 or another other obd1 ecu and get it chipped. ask them to load p29 obd1 dohc zc maps.
ill see if i could get a picture of my civic distributor for all your DOHC ZC people, since there are none on here.
get the correct distributor and you don't need to modify anything, except the wiring
http://www.thezcr.com/forums/showthread.php?t=22444
hey i got the dist and exh. cam angle sensor. also found the upper timing cover in my garage. let me know if you get the thing together and i'll trade this stuff for that front filler piece or something.
pm me and let me know what site you said that b18 block was on.
He wont need that if he's going obd1
freshly boosted DOHC ZC
Jan 12, 2007 11:50 AM
97grnrs
Dec 10, 2006 04:14 PM
crxzcracer
Mar 2, 2005 03:39 PM
