civic si hatch 89. will a non power steering rack fit instead ov powersteering one
Old Aug 22, 2009 | 07:52 PM
bouncingon8's Avatar
Default civic si hatch 89. will a non power steering rack fit instead ov powersteering one
i wana know if a non power steering rack will fit on my hatch instead of the **** power steering one.
Old Aug 22, 2009 | 07:53 PM
BiG ChOr!Zo's Avatar
Default Re: civic si hatch 89. will a non power steering rack fit instead ov powersteering on
si
Old Aug 22, 2009 | 07:57 PM
Fo-Do Fanatic's Avatar
Yes, the non-power steering rack has a sharper turning radius also. Quicker lock-to-lock.
Old Aug 22, 2009 | 07:58 PM
Originally Posted by BiG ChOr!Zo
si
wot
Old Aug 22, 2009 | 07:59 PM
oh thanks mate.. and what year civic do i get it off
Old Aug 22, 2009 | 08:25 PM
frank_el_tanke's Avatar
88-91
Old Aug 22, 2009 | 11:05 PM
ALL EF HATCH POWER STEERING RACKS ARE INTERCHANGEABLE!!!!!!
Old Aug 23, 2009 | 03:47 AM
crxcess's Avatar
you might need to swap the whole crossmember. check the brackets that hold the steering rack on. I've heard the PS ones are bigger.
Old Aug 23, 2009 | 06:55 AM
nfereorhatch's Avatar
The power steering ones are bigger but you don't have to swap the whole crossmember. I am using a non power steering rack off a std hatch on my lx sedan which came with power steering. I used some pieces of rubber i had around the house to take up the difference, been working fine for over 2 years now. Once you put your hands on it you will see what i mean, and also see its not a major issue.
Old Aug 23, 2009 | 09:55 AM
zamis345's Avatar
Did you guys use used racks? Mine is squeaking so I'm pretty sure it's shot.
friscorep
Aug 24, 2006 10:51 PM
thrty8street
16
Nov 24, 2003 06:11 PM
