Honda s2000, 2001 loose of power when vtec engages
Old Aug 22, 2009 | 05:38 PM
chasmataz's Avatar
Default Honda s2000, 2001 loose of power when vtec engages
I get to around 6000 rpm it sputters continues to 9000 rpm.No Engine light or codes. Vtec is working . I removed the solenoid and cleaned, replaced the gasket and screen everything good
Changed the oil and filter .
No vacuum leaks, all new hose
Good oil pressure 85psi
Good fuel pressure 55psi
Replaced coolent sensor
Removed oil pan see if there's any problems, cleaned oil pump filter screen.
checked olms on vtec solenoid , good
Did the map sensor whack , removed and cleaned , had it checked, works
Replaced VTEC oil pressure switch.
New spark plugs
Coils where checked and good
Engine temp is good and within range
New spark plugs
Car acts like you are hitting a rev limiter or something
A/F RUNS REAL RICH BELOW 10.0 ON MY METER BETWEEN 6000 RPM - 9000 RPM
Video
http://www.youtube.com/watch?v=HjQdE..._embedded#t=12
http://www.youtube.com/watch?v=LA7qoLRo168
Old Aug 22, 2009 | 07:07 PM
FaceTuned's Avatar
Default Re: Honda s2000, 2001 loose of power when vtec engages
is this on a stock ecu?
or k-pro / AEM etc.. ?
Old Aug 22, 2009 | 07:08 PM
chasmataz's Avatar
I went back to factory when i noticed this problem so I could trouble shoot the problem.
Yes it is turbo charged , but I unhooked the greddy e management ultimate , put my stock injectors in. unhooked my turbo from the intake and regapped my plugs back to factory standards.
so basically its not using the turbo, Trying to get this working right .
Old Aug 23, 2009 | 08:48 AM
RC000E's Avatar
Dude, just reading your two threads makes it very clear you need to STOP. STOP, ask some intelligent people how to proceed, take your car to someone locally that isn't a dipsh*t, get new management, buy parts that aren't junk and you'll be good. At this point, I'd start over. Take all that sh*t off, recover what money you can, then do appropriate research and build the car right. That or I'll trade you your S2 for my GT3082R built LS/Vtec delsol that's done right...lol.
94wip
12
Jun 20, 2024 07:23 PM
chasmataz
Honda S2000
25
Jan 10, 2010 11:06 PM
blues2k3
Dec 9, 2005 09:53 AM
DC2point0
Aug 30, 2003 07:39 AM
