JR Supercharger vacuum routings
Okay, I finally found enough time to install my JR supercharger on my 95' Honda civic. Install went really well except I have a couple of questions on the vacuum hose routings:
1. The instructions said to run a vacuum hose from the Purge Cut Solenoid valve to the to a fitting on the supercharger by-pass valve. The Purge Cut solenoid valve originally had a line coming from the charcoal canister, where does this line go now? Do I just cap it off?
2. I seem to have an extra vacuum port on the bottom side of the throttle body. Anybody know what goes here, or should I just cap this off as well?
I don't think these two lines go together; the line from the charcoal canister is small (3/16") and the vacuum port on the throttle body is larger (5/16").
I have started the car (with both of these capped) and its running okay at idle, and I don't have a check engine light on, so things seem to be right. Now to get it tuned!
Best Regards,
Darren D. Wall
darrenwall@netzero.net
kirbyator@yahoo.com
1995 Civic DX HB
Go: Gude, AEM, DC Sports, Weapon-R, 5-Zigen, JR SUPERCHARGER!
Turn: AGX, Tenzo-R, Pirelli
Look: PPG, APC, Wings West
Best Regards,
Darren D. Wall
kirbyator@yahoo.com
1995 Civic DX HB
My PCS is still connected to the charcoal cannister. Something changed in this setup from OBD I to OBD II.
Okay, it must have been reallly late Sunday when I got this thing
back together. I found the OTHER port on the Purge Cut Solenoid
Valve and installed the line from the charcoal canister, solved.
The fitting on the bottom of the throttle body that I thought was a
vacuum fitting is actually a coolant line, appartently the return
from the fast idle valve. I combed the isntructions and eventually
came up with this routing: Line from manifold above #4 cylinder to
the fast idle valve, out from the fast idle valve (under the TB)
into the EACV valve, out from the EACV valve back into the coolant
cross-over pipe on the passenger side. Does this sound right?
Best Regards,
Darren D. Wall
1995 Civic DX HB
Go: Gude, AEM, DC Sports, Weapon-R, 5-Zigen, JR Supercharger!
Best Regards,
Darren D. Wall
1995 Civic DX HB
LSej1
Honda Civic (2001 - 2005)
Sep 4, 2017 09:45 PM
prelude9999
Oct 8, 2004 10:01 AM
