Quick Question: Front Discs
Just removing my front discs, but i can't get them off.
The weird thing is, the discs on now do not have retaining screws..there's a pic at the bottom.
Now is there nothing keeping it on or is the axle nut keeping it on. I don't have long enough 8 mm bolts (if there are long ones that i can unbolt from the car to use please tell me where!!) to screw into the holes and i've hammered like crazy and tried using a c-clamp to no avail..
If there is nothing holding it on then i will just keep hammering..
Any suggestions would be greatly appreciated!!
a long bolt is the easiest way. maybe battery hold down bolt??? or run to parts house and grab one
if not grab some penetrating oil, spray around the hub and wheel studs then hold a torch on it for a while. they hit away with a rubber mallet. time consuming but works sometimes.
if it were me i'd still run the the hardware store and grab a long bolt...
ya i would run to the store, but its fricken far from where i am. actually does wal mart sell bolts? they must.. maybe i'll run there
and ya, i'm changing them out
wow..i've been hammering like crazy with a rubber mallet and it doesnt even budge..pb blaster isnt helping at all..i tried prying em off with a crowbar..nothing..broke a battery hold down bolt in 2 places (dumb of me to use that, i know)..i'm gonna see if i can borrow a car and drive to a parts store before they close and buy some bolts..but i feel like that won't help
i am so pissed off right now..
ya i'm changing the discs
i'll look into the puller idea too
you should invest in one
wow i am truly an idiot!! used an actual hammer and it came off (not easily however).
the rotor was just completely mangled though haha. FINALLY!!
thanks a million for the helpful suggestions guys!!
ps the holes in that rotor were for the retaining screws..so that's why the medium sized bolts i tried didnt work (they just threaded right into the hub)
swizz977
25
Dec 31, 2011 02:00 PM
seed2harvest
Honda Civic (2006 - 2015)
22
May 22, 2007 01:45 PM
