My Turbo B16 91 CRX (56k warning)
Old Aug 22, 2009 | 10:22 AM
Navy_CRX's Avatar
Default My Turbo B16 91 CRX (56k warning)
So here it goes
I bought my crx last year with the intensions of building it. when i bought her she had a jdm sirII b16 with a treadstone turbo kit on her. It was fun while it lasted. I have had way to many problems with her first my radiator blew then i got a flat and while my tires were on order she got broken into. Then the big doosey. I was riding around with my buddy when my oil pump fried 8000 rpm no oil it dident last long i broke a rod off and threw it through the block. so over the last 8-9 months i have been collecting parts to rebuild her. I live by the rule "Go big or go home" and for an e-3 in the navy i think i made some good choices.
Picture time
Old Aug 22, 2009 | 10:28 AM
Navy_CRX's Avatar
Default Re: My Turbo B16 91 CRX (56k warning)
so for my rebuild i decided some stuff needed upgrading
I went with
BLOCK
• 84MM darton sleeved B16
• JE 8:1 Compression Pistons
• Eagle H-Beam rods
• JE ProSeal rings
• Acl main bearings
• Cleivite Rod Bearings
• Type R Water/Oil Pumps
• Honda Factory N-1 light weight crank pulley
• Oil catch can
HEAD
• OBD-1 B16 Head
• JDM Civic Type R Cams (B16B)
• Vision Motorworks adjustable cam gears
• USDM Integra Type R Springs (B18C5)
• Skunk 2 Titanium Retainers
• Edelbrock Victor-X Manifold (port matched to head)
• Edelbrock 65mm Throttle Body
• Precision 880cc injectors
• Golden Eagle Vacuum Manifold
Turbo Kit
• Custom Ramhorn Manifold
• Holset HX35W (12cm^2 Exhaust)
• Turbonetics Evolution wastegate
• Greddy type RS blow-off-valve
• Treadstone TR10 intercooler (666HP rated)
• Custom 2.5" downpipe
• Treadstone 2.5" Polished aluminum pipe kit
• Treadstone silicone and T-bolts
Transmission
• JDM S1 transmission
• M-Factory LSD
• ACT 6-Puck clutch
• Fidanza 9.75lb flywheel
• 400hp axles
-OBD-1 Converted with complete Rywire Harness
-Pherable.net Chipped and Socketed P-28 ECU (Tuning On Crome Right now S300 W/Boost soon)
-Walbro 255 lph in-tank fuel pump
-Adjustable fuel pressure regulator with wet gauge
Old Aug 22, 2009 | 10:30 AM
dacrxguy's Avatar
get oem body panels and remove wing
Old Aug 22, 2009 | 10:31 AM
Navy_CRX's Avatar
my old exhaust was way too small so i made a 3" stright pipe for her (gota love no emissions)oh and they are my old tags the cars not even in fl any more
Old Aug 22, 2009 | 10:34 AM
Navy_CRX's Avatar
some more picks for everyone
Old Aug 22, 2009 | 10:37 AM
Navy_CRX's Avatar
and more
Old Aug 22, 2009 | 10:51 AM
.Manny.'s Avatar
Touching My Member
get rid of that CTR crank pulley, get yourself a nice fluidampr harmonic balancer if you want to keep your oil pump from quitting on you again
other than that...sweet build bro...oh and get rid of the ricer crap, ruins a beautiful CR-X
Old Aug 22, 2009 | 11:11 AM
Gunmetal_B20_Hatch's Avatar
It doesnt get any better than girls working on Hondas... :p
Old Aug 22, 2009 | 11:23 AM
Navy_CRX's Avatar
Thats my sister i had her help me with some stuff hoping she will get into cars like i am. And as far as the bodykit goes its a love hate thing i kinda like it buti like the oem look and dont have the money to replace everything if u know what i mean.
Old Aug 22, 2009 | 11:50 AM
SIred91's Avatar
Rainman
Dont listen to the bandwagon retards telling you what it should look like. The only thing I would change personally is the tails. BUT you are boosted, so laugh at the ****ers telling you what it should look like while you pull on em....
Old Aug 22, 2009 | 11:51 AM
SIred91's Avatar
Rainman
Whats up with the roof?
Old Aug 22, 2009 | 12:16 PM
boosted.CRX's Avatar
"• Treadstone TR10 intercooler (666HP rated)"
Haha I like that, wounder if it was intentional?
Old Aug 22, 2009 | 12:18 PM
Navy_CRX's Avatar
Lexan creations plate. It took off 35 lbs and i can still see through it. Its kinda a love haye thing just like the bodykit
Old Aug 22, 2009 | 01:18 PM
miss_pashi's Avatar
New User
There is a lot of love/hate with this car lol!
Old Aug 22, 2009 | 01:44 PM
*ctrlaltdel's Avatar
good luck man, everything looks like it's going well. just because the car doesn't look like a jdm wet dream doesn't mean it's rice. fools... i'd like to do the same over the winter with my b16. keep us posted with results.
Old Aug 22, 2009 | 02:01 PM
Navy_CRX's Avatar
I had a feeling that i would get some remarks about my bodykik/roof/stuff but its ok caus i like her the way she is. I did have a question for HT. im looking for a picture of a wiring harness with all sensor plugs labeled for me. ive tried searching and cant seem to find one. im also looking for a good tuner in/around norfolk va if ne1 knows one let me know. also wondering if anyone has a b16/hx35 dyno chart handy. im looking to make like 450-500 wheel hp with this beast on pump gas but i think i will need bigger injectors/fuel pump/lines and about 100 psi to do it. let me know what you all think.
Old Aug 25, 2009 | 10:46 AM
kaiser_ricer's Avatar
it's a good car but no doubt oem looks better, i'm not aying what the car should look like but it's so hollywood, fast and the furious, that's not us.
it is rice, but if you don't have money, what are you gonna do.the inside is the best. SICK BUILD
Old Aug 26, 2009 | 02:15 AM
Navy_CRX's Avatar
Thanks for the comments. Im gona change the crank pully to an ati or fluidamper as soon as i can. Any more ideas Are apreciated keep em coming guys.
Old Aug 26, 2009 | 04:36 AM
speeddave's Avatar
car and build look good! only other thing i can see is your custom ramhorn manifold looks like a cheap ebay special. two things will most likely happen, first the weight of the hx35 will crack that mani over time. second i think that it will boost creep on you majorly. the ramhorn with a 38mm gate and the big hotside of the holset make for a bad creeping combo.
Old Aug 26, 2009 | 04:02 PM
Navy_CRX's Avatar
see that you have a holset on ur lsv what kind of holset r u running and what kind of spool r u getting on it. I was thinking that ive only got a 1.7 to run a 50 shot direct port kit on her as well as the hx35. What do you all think.
Old Aug 26, 2009 | 04:09 PM
speeddave's Avatar
i'm running a hx35(14cm housing) i get positive pressure at 4k rpm or so then full boost is shortly after as i'm only running 12lbs. your combo will probably spool a tad later than that but it shouldn't be too bad as you should be able to rev a higher.
i ran into issues with my setup and a 38mm gate, mind you it was a topmount but with a big exhaust housing, low boost and a small gate you have a recipe for boost creep. the 90 degree turn the exhaust has to make doesn't help either.
Old Aug 26, 2009 | 04:57 PM
ej1love's Avatar
strait build, motor wise
Old Aug 26, 2009 | 05:12 PM
Navy_CRX's Avatar
Im running a 12cm^2 hotside so that will help a little. As far as exhaust its a 3 in straight pipe with no cat or mufler and as far as the 90 im gona get a full race mani and dp so ill be good.
Old Dec 10, 2009 | 07:56 AM
912's Avatar
912
whats up with build dyno yet? must be out to sea
Garage 808 Hatch
Northwest (Sales)
Feb 12, 2009 05:02 PM
surfinjoe911
Nov 29, 2008 04:58 PM
surfinjoe911
Mid-Atlantic (Sales)
57
Oct 9, 2008 06:12 AM
ShortbusEK
Mar 29, 2008 12:26 PM
C2Imports
Jun 4, 2005 08:08 PM
