What performace radiator are you running?
Old Aug 22, 2009 | 09:11 AM
jeremyrocksursox's Avatar
Default What performace radiator are you running?
I'm thinkin about gettin a higher grade radiator orther then OEM, and I found this one http://www.modacar.com/bolt-on/produ...2528-4585.html
but I also wanted to know if there are any better ones and what other people are running?
Old Aug 22, 2009 | 09:47 AM
Gunmetal_B20_Hatch's Avatar
Default Re: What performace radiator are you running?
eBay has great deals on aluminum rads... I have had 2 and they have worked great(1/2 size & a full size integra rad). Even had bosses for using an OEM fan.
I picked up my 1/2 size for around $75 shipped a month ago.
Old Aug 22, 2009 | 10:00 AM
So I can still use the oem fan or would I have to get a new one?
Old Aug 22, 2009 | 10:11 AM
most likely, yes you can. just make sure the one you get has mounts for the OEM fan. Most of them do.
Old Aug 22, 2009 | 10:26 AM
Ej8_KiD's Avatar
i bought an ebay half size since my oem was broken and used the oem fan , will be upgrading to a mishimoto rad and fan soon thou
Old Aug 22, 2009 | 10:53 AM
D50boy's Avatar
Mishimoto for about 5 years now. Check Ebay.
Old Aug 22, 2009 | 12:53 PM
Oh coool alright well thanks
Old Aug 22, 2009 | 01:14 PM
jkalex05's Avatar
mishimoto radiator, fan, thermostat, switch and hoses. My car hasn't had any issues with cooling since!
Old Aug 22, 2009 | 02:20 PM
Do they sell single fans for the single rads?
Old Aug 22, 2009 | 05:59 PM
?? or does the radiator that i had in my original post work the the oem fan?
Old Aug 23, 2009 | 12:02 AM
boxeocampeon's Avatar
Get a mishimoto radiator theyre really good and you might as well go with the mishimoto slim fan to cus it initiates better cooling. You can run it with an OEM fan but its better to use the mishimoto fan itsa lot better.
Old Aug 23, 2009 | 02:00 PM
i am thinking about replacing my thermostat for the one from mishimoto, but i just got a superstat in december, and jkalex05 how long have you had yours? does it last?
Old Aug 23, 2009 | 02:35 PM
JNocon's Avatar
Koyo.
Old Aug 23, 2009 | 03:31 PM
98civdx's Avatar
Master Detailer
i had a koyo in my integra, and its out lasted 3 motors so far.
Old Aug 23, 2009 | 03:37 PM
jasoncrashtech's Avatar
i use a dual core oem. works good, i'm sure those other ones do also if not better
Old Aug 23, 2009 | 05:54 PM
xXB18EKHatchXx's Avatar
Fluidyne for 5 years now, stock cooling fan, worked great with the stock motor and works great with the B18 that's in there now.
Old Aug 24, 2009 | 06:38 AM
where can i find the koyo thermostat, i just read some reviews on it and it seems pretty ligit, i just can't find a website who sells them
Old Aug 24, 2009 | 06:43 AM
well the mishimoto thermostat opens at a cooler temperature of 140 degrees, and has a lifetime warrenty but, the koyo thermostat opens at 160 degrees, but what i like about the koyo one is that if it breaks it stays stuck open, does anyone know if the mishimoto one does that?
trackDC
21
Feb 25, 2015 06:19 AM
frank_el_tanke
Oct 14, 2014 09:25 PM
ek4_sir
Jun 22, 2009 01:18 PM
smkngsr
Jun 22, 2005 10:46 AM
