Radiator fan not working!
Well recently I had an overheating issue on my b16a2 engine. I figured out the culprit was a leak in a hose from the engine to the heater core. Changed the hose but my radiator fan isn't working.
I checked the fuse and its fine.
Anyone?
Anyone?
try giving the rad fan a direct feed and see if it woks if it does then check the rad fan switch disconnect and bridge the connector if the fan then works it most likely the rad fan switch also check the supplys to the rad fan
what he said, mine had the same problem and the previous owner gheto rigged it so the fan stayed on ALL the time. I just replaced the sensor on the thermostat housing and works like its suppose to
EGed up from the seat up
18
Jun 1, 2011 02:16 AM
