Need help for K20 into EF9 Civic
Old Aug 21, 2009 | 11:21 PM
stn-vik's Avatar
Default Need help for K20 into EF9 Civic
I am going to start a project about put a K20 into EF9, right now I had B16A under the hood. I just wondering that is there any engine mount on the market to buy or I have to do the welding . as for the wiring, can I use the B16 ECU with wiring conversion kit, and where can I buy this. or shell I just put complete wiring of K20 into EF9? Hope someone can help me with those answer!!
Old Aug 21, 2009 | 11:24 PM
0ne-Cam's Avatar
Default Re: Need help for K20 into EF9 Civic
http://lmgtfy.com/?q=k20+engine+mounts
it will say 'hasport motor mount kits'
and
it will say 88-91 civic/crx SECOND FROM TOP K series motor mounts
Old Aug 22, 2009 | 12:14 AM
D16SiHatch's Avatar
for wiring this is what you need
http://rywire.com/store/8891-crxcivi...d93116bfa5816d
Old Aug 22, 2009 | 04:37 AM
richboi's Avatar
I used hasports, and they require welding of the passenger side bracket to the chassis, and the wire harness, You use the k20's engine harness, but you should get rywire's chassis sub harness. as for the ecu, you HAVE to use a K series thats at least reflashed w/o immobilizer, or k pro. everything thing is simple. Kind of. I hope your pockets are deep too man, its an expensive build. good luck.
Old Feb 10, 2012 | 07:13 AM
stn-vik's Avatar
I just wondering that how about the drive shaft??
Honda Del Slow
Dec 10, 2009 03:21 PM
Ceeveek
Oct 9, 2001 10:47 PM
