Speed Needle is below 0?
Old Aug 21, 2009 | 09:24 PM
Syper's Avatar
Default Speed Needle is below 0?
So the other day I went and cleaned up the cluster, took it out and cleaned some dust out. I put it back in and I see that the needle is now below 0? Drove it around and it does go up, but it stays below 0 and then goes up.
Is there away I can get it back on that zero again? i have a 91 CRX
Old Aug 21, 2009 | 09:27 PM
424racer's Avatar
Default Re: Speed Needle is below 0?
did you plug it back in? the cable.
Old Aug 21, 2009 | 09:29 PM
Syper's Avatar
Yea, i plugged everything back in. It reads miles and everything,but my needle dropped below 0 and now it goes up slowly and doesn't give the actual speed.
Old Aug 21, 2009 | 09:52 PM
frank_el_tanke's Avatar
open the cluster so that you can turn the speedometer needle clockwise. once it goes about 3/4 of a full rotation you'll feel some pressure, turn it a little more then let go and see where the needle rests. keep adjusting until your satisfied.
Old Aug 21, 2009 | 10:08 PM
Syper's Avatar
Wooo! Thanks!!!
Will hopefully fix it tomorrow!!
Old Aug 22, 2009 | 11:47 AM
Syper's Avatar
Just tried it and it didn't seem to work. The needle just went below 0 again.
Old Aug 22, 2009 | 05:21 PM
Syper's Avatar
Still need help!
Old Aug 22, 2009 | 05:43 PM
dang, new cluster then. what year and type of cluster do you have?
Old Aug 22, 2009 | 08:32 PM
Syper's Avatar
Ugh!!!! Dang for real!!!
I have the stock 91 CRX cluster....
I was really hoping that it could be fixed and I wouldn't have to go out and find another one...
Old Aug 22, 2009 | 08:40 PM
BiG ChOr!Zo's Avatar
http://losangeles.craigslist.org/sgv...332130878.html
Old Aug 22, 2009 | 08:56 PM
Syper's Avatar
I feel sad now...
Old Aug 22, 2009 | 09:08 PM
how many miles were on your cluster? i have a cluster for parts, but it reads 284k. where in la are you?
Old Aug 22, 2009 | 09:34 PM
Syper's Avatar
It has around 174-175.
I'm in South la.
406EVO
May 18, 2016 11:26 AM
TMC_EF
Jul 16, 2007 08:39 PM
gwchndlr
Mar 20, 2007 03:20 PM
TurboEM1
Jun 16, 2006 11:37 AM
mc
Apr 19, 2004 07:58 PM
