cant figure this out
Old Aug 21, 2009 | 05:00 PM
project91crxsi's Avatar
Default cant figure this out
my 91 crx has been having problems, when i go to start it it takes a few tries and i have to get on the gas a bit to get it running, then it idles good, then i take it for a ride and it runs fine, then a few minutes later the check engine light comes on and it starts bucking and running bad, if i turn it off it goes away for a few minutes then comes back but the bucking stays, it idles really ruff after its warmed up like slowly climbs to 1k then drops to about 300 and stays around 200-500 then climbs alittle again. never shuts off tho. the code its throwing is o2 sensor, but i just replaced it and took it for a ride and same thing. any ideas? its a d16y7 obd0
Old Aug 21, 2009 | 05:57 PM
Default Re: cant figure this out
someone help me out, this problem has been here since i got the car and i cant figure it out
Old Aug 21, 2009 | 07:34 PM
negro_1087_delta's Avatar
do u still have problems so i can try to help u
Old Aug 21, 2009 | 07:52 PM
what?
Old Aug 21, 2009 | 08:30 PM
Turbo Dan's Avatar
taken from another thread:
I was getting a periodic code 1 and it turns out it was in response to a small vacuum leak.
my guess is you have a vacuum leak somewhere that is triggered by some movement in the engine bay.
check all your lines.
or get a vacuum gauge, they're cheap
Old Aug 22, 2009 | 06:09 AM
maybe ill have to check, and you said movement in the engine bay, my motor mount is going so theres alot of movement lol, theres this weird nipple like thing on the tube going from the intake to the head that a bit of air comes out of and i never saw it on any one else car
Old Aug 22, 2009 | 06:12 AM
you can see it in the bottom left of this pic http://i98.photobucket.com/albums/l2...2091649-00.jpg
Old Aug 22, 2009 | 08:40 AM
anyone? this has had to happen before to someone
Old Aug 22, 2009 | 09:35 AM
hello again yes it happened to my friend but first you have to see in your computer what codes are comming out on the bottom of the passenger side foot lift the carpet then with key on motor off check the codes but only when the motor is going bad or when the check engine light comes on because it sounds like its the map or the oxygen sensor
Old Aug 22, 2009 | 09:41 AM
o i forgot to tell u that i am running the same setup the y7 but with diffrent pistons the oxygen sensor should be like if it were an integra da in the down pipe not in headder itself like the rest of the efs
Old Aug 22, 2009 | 06:58 PM
mine only has 1 o2 sensor and its on the header, thats how i got the car, theirs another o2 sensor right before the cat but its not wired up and looks like it might be bad, the check engine light says error code 1- o2 sensor on exhaust manifold which is the one i just replaced
Old Aug 22, 2009 | 07:05 PM
i replaced it with an unheated o2 sensor because thats what was on it if that matters
Old Aug 22, 2009 | 07:36 PM
also when its idleing ruff i turned the idle screw all the way open and it did nothing
Old Aug 22, 2009 | 07:50 PM
what i am trying to say is that instead of using the o2 outlet infront use the back one only
Old Aug 22, 2009 | 08:03 PM
what do you mean? put the good o2 sensor before the cat and hook it up and not hook one up on the header?
Old Aug 22, 2009 | 08:31 PM
GroundZer0 336's Avatar
im thinking you have a vacuum leak. a tiny one that just leaks from your motor moving sometimes...o2 sensor wont really do anything like that on an obd0 car it just runs in closed loop. i never even ran an o2 in my obd0 b18 crx and never had any problems. you can get a can of starting fluid or carb cleaner and spray it over the vacuum lines with the car running, if the idle changes thats where you have a vacuum leak.
Old Aug 23, 2009 | 06:57 AM
alright ill try that, would a vac leak cause a CEL for o2 sensor since the air/fuel ratio is being messed up?
Old Aug 23, 2009 | 07:43 AM
also for a faster way try to put your hand in front of the mouth of the intake manifold without the intake of course lol if it doesnt die it means that it has a vac leak
Old Aug 23, 2009 | 07:45 AM
yea but cant it die if its not a big leak?
Old Aug 23, 2009 | 07:51 AM
when somsthing gets cold it expands and when its hot it shrivels if its causing that much problems it will work but if u remember what the other guy said use carb spray or wd40 to add to it youll be fine
Old Aug 23, 2009 | 04:45 PM
okay i found the vacuum leak, put on a new hose and it ran good, then i drove it and no CEL but car is still bucking like hell and when i got back it was idleing around 300 rpm real ruff, sometimes still rises and falls. i cant figure this out
Old Aug 23, 2009 | 04:53 PM
Mr. DeOro's Avatar
I believe that bad idle is you idle air control valve and possibly a dirty throttle body.
Old Aug 23, 2009 | 04:58 PM
after i changed the hose i cleaned out the iacv, and sprayed cleaner in the throttle body
Old Aug 23, 2009 | 07:24 PM
i was driving it again and it idles bad still, and i cant tell if the jerkiness is a problem or if its because the gas pedal is so damn soft for some reason, i barely touch it and its on the floor, its so hard to be smooth on it that it seems to cause the car to jerk really bad, you cant be cruising your either on it or off it
Old Aug 24, 2009 | 07:54 AM
bump need this thing running for school in a week
