ball bearing grease boot damaged?
Old Aug 26, 2002 | 05:05 AM
1swoosh's Avatar
Default ball bearing grease boot damaged?
I just used the fork at autozone to remove my axle, and i ripped the rubber boot where the ball bearing joint is. what should i do?
Old Aug 26, 2002 | 07:15 AM
Civic1992DX's Avatar
Default Re: ball bearing grease boot damaged? (1swoosh)
take off the axle, disassemble the inner joint, pull the outer boot (the one that got damaged, I assume), regrease with fresh CV-joint grease, slip the new boot on & re-assemble everything inreverse order.
Don't drive with ripped boot, axle is much more expensive than the boot & pack of grease.
Yuri K
Old Aug 26, 2002 | 07:34 AM
lagger's Avatar
buy another boot, pack it with grease, and reinstall it. the clips are a PITA though. next time you can just turn the wheel to the side, and hammer down on the control arm to pop it loose. or there is another tool that you can use to pop the ball joint, it looks like a C, there is a picture in the helms manual of it. that tool would be ideal, but hammering on the control arm works good too.
Old Aug 26, 2002 | 09:58 AM
Default Re: ball bearing grease boot damaged? (lagger)
oh, my bad, I thought that he ripped the CV joint boot. Just do as lagger said...
Yuri K
Old Aug 26, 2002 | 10:25 AM
swoosh1's Avatar
Default Re: ball bearing grease boot damaged? (Civic1992DX)
anyone know the part number for the boots?
Old Aug 29, 2002 | 04:51 AM
1swoosh's Avatar
Default Re: ball bearing grease boot damaged? (swoosh1)
ok i got the boots from honda and new clips, whats the best way to remove and install these clips, it looks like its gonna be a pain in the ***? anybody?
retriever99
Jan 8, 2020 07:12 AM
Jimster480
Jan 22, 2010 10:58 AM
oldskoolDA6
Jul 9, 2009 11:39 AM
mums_car
Jul 11, 2004 10:44 PM
GruvyTune
Jul 22, 2002 10:01 AM
