valve releifs?
Old Aug 21, 2009 | 02:36 PM
wbaldwin_86's Avatar
Default valve releifs?
hello,
i have searched for a few hours on this topic. i have a b20z2 with a stock gsr head and oem head gasket. I would like to run ctr cams and i am wondering how big of a valve relief i will need to cut, if any. i have had many mixed inputs on this topic, some say i need to cut larger valve reliefs and others say i can run these cams without cutting the reliefs. so any input would be greatly appreciated.
Old Aug 21, 2009 | 04:36 PM
96halx's Avatar
Default Re: valve releifs?
If you can't get a straight answer, try claying the piston to check the clearances.
Old Aug 21, 2009 | 05:17 PM
JDM JEFFREY's Avatar
you will hit the piston....
Old Aug 21, 2009 | 06:19 PM
how much larger do the reliefs need to be made?
Old Aug 22, 2009 | 04:55 AM
00Red_SiR's Avatar
All Motor Mentor
large enough to clear the valves.
Old Aug 22, 2009 | 10:51 AM
is there any link on how to do this?
Old Aug 22, 2009 | 10:25 PM
thumper64's Avatar
IDK, but I'm sure you'll need a Dremel or something similar. And also, you want I believe something like .02" extra clearance. The rod will slightly stretch at high RPMs.
An OEM head gasket is something like .03", so if you just laid 1 layer on and had exactly .00" then it would be good with 3 layers. Maybe my math is wrong, but just an idea.
Old Aug 23, 2009 | 07:44 AM
00Red_SiR's Avatar
All Motor Mentor
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/b20-vtec-piston-myth-1320610/
Good info.
Old Aug 23, 2009 | 09:26 AM
thank you very much for the info! i opened up my service manual and found out the difference in gsr and type r cams.
intake cam
primary -.013
mid .019
secondary .005
exhaust cam
primary -.013
mid .025
secondary .012
thank you very much for this info it helped me alot
Old Aug 23, 2009 | 04:30 PM
well i took off .04" off, i am going to clay the motor tonight to see if that was enough.
Ac01031234
Engine Machining & Assembly
Nov 20, 2016 11:36 AM
narfdanarf
19
Nov 3, 2010 10:07 PM
JDMEK9R
Feb 19, 2008 02:42 PM
AViciousTHRUST
Jul 28, 2006 05:55 AM
Tech6023
Sep 12, 2005 09:26 PM
