megan racing coilover sleeves
they are as good as any other sleeve coilover really.. the big difference is in what spring and shock you are using. if you don't use progressive springs or stiffer springs than stock and you adjust those for a big drop, you will probably blow your shocks and spend most of your time on the bump stops after that..
Come on! Are you really gonna bag on the guy cuz he posted this here instead of the suspension part of the forum? Get over yourself. And give good input, and if you don't have any, then keep your comments to yourself!!
i dont see where he realy broke the rules....cuz its in crx /ef thread ima bet he has one of the 2.... he didnt where he could buy them at, all he asked is if they are good. maybe u should read number 9?
like chorizo said this would be better off in the suspension thread infact it has already been asked and solved there. The reason that they have suspension threads is to remove clutter from other parts of the board.
