Suspension & Brakes Theory, alignment, spring rates....
ground control coilovers
Old Aug 21, 2009 | 10:44 AM
type-ONE's Avatar
Default ground control coilovers
Hi all @ HT
i need help and feedback about the ground control coilovers...
ı have the intend to use gc coils with stock shocks....
what r u guys thinking about this combo any opinions or experiences with it ?
Old Aug 21, 2009 | 12:15 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: ground control coilovers
don't expect to go very low before the shocks blow out, what spring rate are your coilovers?
Old Aug 21, 2009 | 12:29 PM
type-ONE's Avatar
my car is totaly stock for now...ı wanna drop it about 1,5 inches....but first off all before i buy it ı wanna know how is the ride quality....?? hope it's not so stiff...??
Old Aug 21, 2009 | 12:56 PM
sayyoooon's Avatar
it all depends on what rates you get, how low you drop it, but either way stock shocks won't last long.
Old Aug 21, 2009 | 01:53 PM
type-ONE's Avatar
any other feeds...
Old Aug 21, 2009 | 02:11 PM
mike-y's Avatar
coilover springs are usually a lot stiffer than your regular lowering spring, so you will blow your stock shocks after a while. Maybe even right away if you lower the car a lot.
If you want to keep your stock shocks, then you have to get a very mild lowering spring, no coilovers.
but GC's can have a decent ride, as long as you don't get super stiff spring rates, and you pair them with decent shocks that can handle the new spring rate.
Old Aug 21, 2009 | 05:51 PM
racebum's Avatar
Originally Posted by type-ONE
any other feeds...
what is it you want to hear?
ground control sells custom rates. how it rides, handles and everything else are directly impacted by the rate you choose. if you have stock shocks and want a mild drop order 300f in an 8" spring and 250R in a 7" or 8" spring out back. those rates are a bit more firm that factory but won't blow stock shocks as long as you don't get excessive with the drop
Old Aug 22, 2009 | 01:28 AM
type-ONE's Avatar
what is spring rate ? is it from factory wise a special rate which determined by the production or is it how drop i set the coils ??
Old Aug 23, 2009 | 04:59 AM
Tony Torque's Avatar
How bout on a '03 s2000 w/ stock shocks?
Old Aug 23, 2009 | 11:31 AM
racebum's Avatar
you ever notice how some springs feel stiffer than others? well they rate them in various ways. pounds per inch simply means that it takes X number of pounds to compress the spring one inch. the factory rates are something like 250LB/IN up front and 120LB/IN out back. with your ground controls you move the rates up slightly, like i was saying 300lb/in front and 250lb/in out back. as long as you don't go lower than a two finger gap they will live for quite awhile.
Old Aug 25, 2009 | 08:20 AM
mike-y's Avatar
stock rates on an EF are more like 150-160 lb/in up front and like 80-90 in the rear. 300 lb/in is going to be quite a bit stiffer. factory rates are no where near 250. For reference, the 94-01 integra GSR's rates were 200/100 F/R.
Old Aug 25, 2009 | 12:03 PM
racebum's Avatar
the front dc2 rate is something like 248, 258lb?, the rear is 110 if i remember right. {actual rates are all posted on team integra} the itr uses a progressive to get similar front and rear rates. 300/250 is the same rate as the dc2 tein h tech lowering spring which a person can use on stock shocks with zero issues. as long as you don't slam it the rear rate increase just dials out some of the factory understeer.
Old Aug 26, 2009 | 07:27 AM
type-ONE's Avatar
thank you much for the explanation that was a good info for me..
Old Aug 27, 2009 | 11:48 AM
mike-y's Avatar
the factory rates are not that high . The ITR was about 250/250, linear rate up front, progressive in the rear. The H&R OE springs I had on my GSR were 280/190 and they were considerably stiffer than the stock springs, so I don't believe the stock GSR rates were 250+.
I did a quick search on team integra (and a couple of other sites) and came across this info on both:
For 96-00 Civics (EJ6-8 and EM1 chassis codes)
96-00 EX - 165F/80R (P/P)
99-00 Si (EM1) - 201F/99.8R (P/P)
97, 00-01 ITR - 250F/250R (L/P)
GS-R - 200F/95R (P/P)
CTR - 240/240 (L/P)
L = Linear, P = Progressive rate
There is a wheel rate thread on team integra, and that guy posts some different numbers, but they are still close to above, at 212/117 lb/in on a stock integra.
Old Aug 27, 2009 | 01:46 PM
racebum's Avatar
double checked, they were 212/117 with the itr at 248 on either end. i still fail to see what stock numbers have to do with setting the car up though. 300/250 will live for years on stock shocks and not feel underdampened as long as the drop isn't excessive. the factory gsr rear shocks actually have more rebound with the hand dyno than a tokico blue.
Old Aug 27, 2009 | 03:09 PM
RomesEM1's Avatar
PIC apex 776 shipped. thmotorsports..good deal? or $800 gc/koni?
Old Aug 27, 2009 | 03:14 PM
racebum's Avatar
i'd prefer the gc/koni since you get a better shock and adjustable rates. however, you're now at least talking about two quality choices. the pics would probably be better for a really low ride since they offer the ability to go down without touching preload. the koni/gc combo can be the better of the two on the track but aren't really designed to go under a 1 finger or maybe flush gap
Old Aug 27, 2009 | 03:45 PM
sayyoooon's Avatar
Really? So are people who say koni/gc ride comparable to fullbodied coilovers while dumped or tucking are lying? Just want some clarification on the matter really.
Old Aug 27, 2009 | 04:05 PM
racebum's Avatar
gc koni are full bodied coilovers, well, like tein coilovers. see the pic's, skunk c's and a few others use a screw in adjustment that lets you lower ride height without touching preload. this lets you drop a car and maintain shock travel. with koni, tein and other coilovers that use preload lowering, you lower right into shock travel. you can really help this out with extended top hats or honda mounts as the guys at GC call them. it buys you around one more inch of travel.
watch this skunk video, they show you what i'm talking about so you can see it with your own eyes
http://www.skunk2.com/skunk2_video.php?code=COVC
Old Aug 27, 2009 | 04:17 PM
sayyoooon's Avatar
Ahh so due to PIC's leaving preload alone, they'll still ride better than koni/gc's with extended top hats? for tuck/dumped.
Old Aug 27, 2009 | 05:18 PM
racebum's Avatar
it's not really ride better, it's perform better. i still don't know what "ride good" means when people say things like this. how a car rides is so subjective. i would have to see the car and what it runs into. i know with the extended top hats you can get pretty low with the konis if for some reason you want to do that. it's just the pic or pro c design is a better one for people who run really low
Old Aug 27, 2009 | 05:23 PM
sayyoooon's Avatar
I don't really want to be dumped to the ground, but I'd like flush at the least and tucking a little tire if possible. So I just wanted to know which would be "better", I know qualitys never going to be good.
Old Aug 27, 2009 | 05:41 PM
racebum's Avatar
i think you would be happier with the pic setup since it will maintain shock travel as you sound like you want to run pretty low. i'm telling you though. the first time you run a rough road at high speed you're going to scare yourself
Old Aug 27, 2009 | 05:49 PM
sayyoooon's Avatar
Yeah i've been following your posts lately and it's making me rethink it more and more. A flush stance wouldn't be too bad then would it? I'd still be able to have good handling with that right?
Old Aug 27, 2009 | 05:58 PM
racebum's Avatar
it all depends on what you're after, this is my car on koni/gc, the suspension works GREAT at this ride height. i could probably go a hair {half inch} lower if i wanted to and still maintain a great balance. i have a couple of different sets of wheels, these are rays 17s
