speed sensor?? opinions...
a little while ago my speedometer and my odometer stopped working first thought was that it was my speed sensor but there is no check engine light so the ecu isnt throwing a code
some help would be nice before i buy a new speed sensor
Do you have a multimeter to measure resistance or continuity? If so, measure continuity (<1 Ohm resistance) between the VSS and cluster ends of the wire. If there's no continuity, then look for a break in the wire and repair. Also check whether the problem is a bad terminal for the wire in the cluster or cluster connector.
just trace the wire down to the cluster.it just happened all of a sudden or were u messing with it and it happened?check the fuses if u havent already
steve.kelloggs
Sep 22, 2008 08:13 PM
EGed up from the seat up
34
Sep 16, 2008 06:37 AM
duneracer69
Nov 6, 2005 06:50 PM
