Anyone w/an MFactory LSD stripping splines on axles?
Old Aug 20, 2009 | 08:00 PM
JFK78's Avatar
Default Anyone w/an MFactory LSD stripping splines on axles?
Anyone here w/an MFactory LSD stripping splines on axles? If so please chime in!
Not blaming anyone here, just trying to figure out the axle spline stripping issue we've been having with new DSS 5.9's and an MFactory LSD. Any help would be greatly appreciated.
Info is here on pg.9
https://honda-tech.com/forums/drag-racing-36/speedfactory-09-s-c-build-thread-2584591/
Old Aug 20, 2009 | 08:50 PM
CETVTOGEM's Avatar
Default Re: Anyone w/an MFactory LSD stripping splines on axles?
sounds like a broken diff
Old Aug 20, 2009 | 08:53 PM
RedneckRicer's Avatar
looks like the diff might be a little larger than the axles. how do the teeth on the Diff look?
Old Aug 20, 2009 | 09:01 PM
jarvis199's Avatar
ill be the funny guy... should bought an obx! lol
but seriously, id like to know whats going on i was about to buy one for my teg!
Old Aug 20, 2009 | 09:26 PM
A train's Avatar
we have no problems with the 5.9's with the m factory diff! we know the car makes well over 900+!
Old Aug 20, 2009 | 09:42 PM
JFK78's Avatar
The diff is perfect, no damage.
I'm not trying to blame the diff at all, just looking for some input to help figure out our issue. I've installed plenty with zero issues.
Good to know, thanks for the input.
It just looks like the stripped splines maybe only engaging part of the spline i.e.- mis-machined or something. It's hard to believe the DSS spline is so soft that it could strip just from doing 1 burnout.
Old Aug 21, 2009 | 04:28 AM
turbotypeR@SPEC's Avatar
25 Year Member
Got any pics? It is very common for the passenger side to have problems when you are laying alot of power down. Several of us have had problems with it. The drivers side inboard splines are just too small. That's why you see alot of people using the pro levels or even mark williams now
Old Aug 21, 2009 | 06:20 AM
Clayton's Avatar
H-T Administrator
25 Year Member
https://honda-tech.com/forums/showthread.php?t=2584591
Have you contacted the manufacturer about this yet, to see if they have any insight?
Old Aug 21, 2009 | 06:25 AM
MFactory's Avatar
Sorry, just heard about this. We have lots of customers running the 5.9's on them with no problems whatsoever. Infact, this is the first time I've even heard of someone having a problem like this.
Have you put the tranny back together, or is the diff still out? If you hit me up on email and we'll see what the problem is
Old Aug 21, 2009 | 07:48 AM
locash's Avatar
We had the same problem with a DSS 5.9 and the Mfactory diff.. We just assumed the axle popped out because it wasn't properly installed.. Passenger side axle..
Old Aug 21, 2009 | 07:58 AM
MFactory's Avatar
Did the problem re-occur after changing the axle?
Old Aug 21, 2009 | 09:19 AM
JFK78's Avatar
Thanks for all the input guys.
Again, I'm not blaming the MFactory LSD, just trying to gather info to help narrow down the issue.
We have to pull the tranny again so it'll be out.
These were both clipped in place, they didn't pop out. Both newer 5.9's.
The 1st one we ordered ~6 months ago, the 2nd one was just ordered a week ago.
Yes, immediately. Brand new 5.9, did a burnout in the waterbox and it was stripped. We couldn't even stage the car.
Old Aug 21, 2009 | 09:31 AM
MFactory's Avatar
Sorry, that question was for Locash :p
But yeah, it certainly does seem strange for this to be happening, and especially so if it is only with these 5.9's.
Have you checked the measurements of the axle splines against a non 5.9?
Got traction's Avatar
were you able to make the passes for your license?
Old Aug 21, 2009 | 09:42 AM
reaction360's Avatar
Yes, congrats to Kevin on getting his license.
Old Aug 22, 2009 | 09:35 AM
Full-Race Henry's Avatar
actually, we couldnt get another axle seated in it. We changed out the inner of the dss 5.9 axle and it wouldnt go in all the way and would bind up. we pulled the trans, tore it down, switched out the mfactory lsd to a quaife that i had laying around and threw it back together so we could start our journey to fontana for IDRC.
The weird part is after we got the replacement parts and we reassembled the mfactory lsd, we couldnt get the axle to slide in smoothly and lock, until Jeff (White.:R32) did something to it. I think he had to sand a little section that the axle scared up.
Old Aug 22, 2009 | 11:33 AM
CETVTOGEM's Avatar
i had this happen with my 5.9 in a quaife, i also thought it was do to soft metal, but turns out the quaife had broke that pass.
Old Aug 22, 2009 | 12:21 PM
Mr. Em1's Avatar
that makes me wonder, when i installed my passenger axle it didnt make that pop noise that it makes when it goes in all the way, but it looks as if it is in all the way
(mfactory lsd and 5.9's here too)
Old Jul 18, 2010 | 03:30 PM
KENNYbuiltEG6's Avatar
this just happend to me and it was the lsd that broke... the lsd looks fine when you look in it but upon taking it apart for further inspection the right side axle gear fell apart into several pieces... btw im looking for a right side dss stage 5.9 inner spline assembly... please lmk
Old Jul 19, 2010 | 09:40 AM
5Star_'s Avatar
We have the same issues on the s2000 Mfactory lsd
Old Jul 19, 2010 | 11:26 PM
MFactory's Avatar
All Helical LSD's are covered under warranty. Please PM/Email us with the details. Thanks!
Old Jul 20, 2010 | 07:13 AM
narfdanarf's Avatar
Does the warranty cover my axles also?
Old Jul 20, 2010 | 02:47 PM
hondaracing84's Avatar
I read a Thread on here about a car running dss axles and mfactory diff that had the exact same problem. They kept changing axles and kept having the same problem. They found out that the diff had a very thin (hairline) crack in it where the axles inserted. When they did the burn out and launched the car the part of the diff where the axles went in would separate because of the crack and strip the splines on the axle. If I could remember the thread and who started it Id tell, but its been a while.
Old Jul 21, 2010 | 02:27 PM
welfarepc's Avatar
IIRC that was speedfactory. the creator of this thread. im sure they checked for that same issue already.
Old Nov 23, 2010 | 02:37 PM
C0MEgetS0ME's Avatar
I have a qauife lsd with autozone axles, this just happened to me a few weeks ago. the passenger side axle splines were stripped. but it looked like my axle popped out becasue only about an 1" of the splines was stripped and not the entire length of the splines. and my lsd looked fine all the splines were good. it happened as I was 2-step at 7k. 502whp
