tach problem
Old Aug 25, 2002 | 11:59 PM
crashtest Sonny's Avatar
Default tach problem
my tach goes wild by the needle jumps up and down when i step on gas. its not accurate rpm reading. its like either the needle is loose. or there is problem in the distributor. i hooked up my shift light to the distributor thinking my tach is messed up ..but when i rev to check the light..the needle lights up according to the needle. if i just tap on the gas a little bit..the needle can jump all the way to 5k or even 6k. i dont kno if i am makin sense....=\ i just hope somebody knows what i am talkin about
Old Aug 26, 2002 | 03:49 AM
keithv's Avatar
Default Re: tach problem (4g_civic_si)
open up the tach and make sure all the wires are tight. loose wires can cause the tach to go crazy.
if that doesn't work, try replacing your ignitor. that seems to be the problem on alot of d series distributors.
[Modified by breaka_1_9, 8:22 AM 8/26/2002]
Old Aug 26, 2002 | 04:12 AM
USDM 4G VTEC's Avatar
happened to me and did it evenyesterday
make sure the cable from the tach that goes to ur blue cable on the dizzy its tight and its doing a good contact.. mines does it when the cables are a little loose.....
Old Aug 26, 2002 | 01:04 PM
Default Re: tach problem (JDM EF9)
i dont kno if you guys are thinking its a autometer tach..but im talkin about the tach on my cluster..and i kno for sure the cable to the blue wire is on tight because its connected on the right way.. i have a few people telling me its the distributor..but im not totally sure. its been happening ever since but its finally getting annoying. its been happening before i install my shift light.
Old Aug 26, 2002 | 01:07 PM
Urban Business
Guest
Posts: n/a
i created that problem 2 days ago. i was pulling wires off my coil and then the tach went to **** on me. its a bad connection sme where alng the negative side of the coil
Old Aug 27, 2002 | 03:09 AM
keithv's Avatar
if all your wires are connected tight, then swap out the ignitior for a known good one and see if that fixes the problem.
Old Aug 27, 2002 | 03:23 AM
jasyatz's Avatar
Default Re: tach problem (breaka_1_9)
Check and make sure all the ignitor wires are tight before you swap them out. Chances are, some if not all of the ignitor connections are loose..
Does the car hesitate or stumble at all??? If it does, the ignitor connections are definately loose...
A bad ignitor will cause a rough run, stalling, no start and tahc problems. If you have just ne of these problems, the connections are loose, or might be in the tach itself. Haven't seen a tach go bad myself however..
Jeff
Old Aug 27, 2002 | 06:56 AM
Default Re: tach problem (jasyatz)
actually the car doesnt hesitate or stumble..in fact it runs well .. i dont have rough run..stalling...or no start...well dis is when it start to happen after i install some indiglow... would this help? would the indiglo might have hit the needle and made it loose..? but if that is the problem..when i put in my indiglo i touch all the needle by accident when i was tryin to put them in..
Old Aug 27, 2002 | 08:28 AM
Hondasaurs's Avatar
You might want to replace your cap and rotor too.
Old Aug 28, 2002 | 07:39 AM
Default Re: tach problem (ZC_CRX)
i think my cap and rotor is new. i just got it replaced like a short while ago.
Old Aug 28, 2002 | 07:41 AM
Hondasaurs's Avatar
Is it an aftermarket tach?
Old Aug 28, 2002 | 01:11 PM
no..its the tach on my cluster. i just have a shift light.
Old Aug 28, 2002 | 04:23 PM
d-wreck's Avatar
your probablem is a bad ground somewhere. it could be the ground under the dash or the ground that is behind the instrument cluster. does it happen when other acessories are going or just the tach. if it just the tach its probably the under dash one because the one behind the cluster is that plastic one and the grounds are distributed to other items from one large ground
hope this makes sense and helps
derek
Old Sep 4, 2002 | 04:20 PM
raceboy71's Avatar
I have a 90 si with the same problems, although mine seems to hesitate at high rpm. The ignitor was replaced, but I think it is faulty, from all the posts I have read. I think it is deffinately the ignitor, as it never had this problem before it was replaced, and although they played with the wiring, it has never worked 100%. I hope this helps..
cheek32
Jun 27, 2011 06:24 PM
soad1234
Aug 19, 2007 01:45 PM
CimorelliCRX
14
Jul 2, 2005 02:25 PM
5thgenCory
Jul 18, 2004 12:08 PM
brawl
Nov 7, 2001 02:57 PM
