oil leak
Old Aug 20, 2009 | 06:19 PM
Christopherian1982's Avatar
Default oil leak
I have a really odd leak thats coming from my distributer bottom screw on the black cover piece. Can oil leak there? I've been watching it and its definantly leaking from that screw. How do i fix this? Is there a gasket i can replace.
Old Aug 20, 2009 | 06:31 PM
Laz's EP's Avatar
Default Re: oil leak
I have the same problem. Is it on a B16A2?? I thought it was the Vtec solenoid gasket. I changed it and it wasn't that.
Bump for an answer
Old Aug 20, 2009 | 06:33 PM
Bump for an answer
I also have B16a boosting.
Old Aug 20, 2009 | 06:38 PM
Laz's EP's Avatar
It sucks, because if I dont keep my eye on it, the oil will leak down to my tranny
Old Aug 20, 2009 | 06:39 PM
-Gambit-'s Avatar
buy new dizzy o-rings.
Old Aug 20, 2009 | 06:41 PM
Laz's EP's Avatar
Thats it???? Buying some tomorrow, How many does it take?
i have that problem now... Everyday before i go to work i check my dip stick just to check the oil level... Please does anyone know what or how to fix this.. Im almost to the point of buying a new dist. just to see if it will fix it.....
Old Aug 20, 2009 | 06:45 PM
Laz's EP's Avatar
LOL I have to keep a spare napkin to check the oil everyday and wipe off the excess oil drips
Old Aug 20, 2009 | 06:48 PM
HAHA me too....
Old Aug 20, 2009 | 06:50 PM
Blurkey's Avatar
Take distributor cap off and see if you have oil in the bottom of the cap with oil inside the housing. If oil present then the distributor shaft seal is leaking. This is not too common.
Gambit's suggestion of a new distributor is probably the cause of the leak as this is very common problem.
If you take the dizzy off and don't have a timing light make shure you scribe the top tang of the dizzy with a mark going from dizzy to head so as not to mess up the timing.
You only need 1 o-ring, it,s a cheap fix.
Old Aug 20, 2009 | 06:52 PM
earlylocks's Avatar
it maybe a cam seal leaking, very common on hondas!
Old Aug 20, 2009 | 06:57 PM
Laz's EP's Avatar
My cam seals are new, in order to change the oil ring on the distributor, we need to take it out? That sucks
Old Aug 20, 2009 | 07:06 PM
Jimster480's Avatar
its not hard to do and the seal is like $10 from Honda.
Old Aug 20, 2009 | 07:09 PM
-Gambit-'s Avatar
just take out the 3 screws that hold on the dist. then you will see the o ring on the dist shaft that goes into the motor.
Blurkey's Avatar
Changing the o-ring is easy! Scribe top o dizzy, disconnect harness and undo 3 bolts.Then just pull it out and be prepared for huge oil spill as the remaining oil in the gallery will flow out. Change seal, clean and reinstall. Take not of how the shaft tangs are lined up for the cam. If you mess up the orientation the dizzy will not fit flush with the head when you reinstall.
It's a 10 minute job, 20 if you take a break and have a beer.
-Gambit-'s Avatar
true story.
Old Aug 20, 2009 | 07:14 PM
Laz's EP's Avatar
So its just take off the three bolts and pull the distributor out and change the ring? Is the right?
Thanks
Old Aug 21, 2009 | 06:08 PM
dizzy is the distributor?
Old Aug 21, 2009 | 10:42 PM
Jimster480's Avatar
yes
Old Aug 22, 2009 | 07:07 AM
Laz's EP's Avatar
Well I picked up the oil ring yesterday and I will install it in a few. Hopefully thats my problem , my friend at Honda told me that it can also be the seal on the dist itself and if it is I would need to change the dist.
Old Aug 22, 2009 | 07:11 AM
GSaura's Avatar
Thanks
yes, that's right. VERY common for these to be sources of strange leaks on honda motors. Good luck.
Old Aug 22, 2009 | 10:25 AM
Laz's EP's Avatar
Well I did it, it took about 10 mins, very easy. The old ring was hard and when i pulled the dist out, no oil spilled. I took it for spin, hit vtec a couple of times and got back and no oil. So I would say that my problem was the oil ring, After all this time it was a stupid oil ring giving me headaches. lol
To Chris, I hope you have the same luck. Remember to mark the dist on top with 2 lines in order to install the right way.
Old Aug 22, 2009 | 12:45 PM
-Gambit-'s Avatar
good stuff, im glad your oil leak is fixed.
Old Aug 22, 2009 | 07:01 PM
Thanks for the helpfull info fellow honda-tech members..... I also fixed my problem.... SO SO Glad... Thanks again...
davey5300
May 7, 2010 06:01 PM
jeremypr
Aug 2, 2009 05:05 PM
jdm ek9 101
May 10, 2007 11:30 AM
lOOkatme
Mar 26, 2006 08:28 PM
NaisBest
Mar 2, 2005 07:38 PM
