integra shifter in a civic?
Old Aug 25, 2002 | 11:52 PM
Cat's Avatar
Cat
Default integra shifter in a civic?
i gotta stock '97 civic, i was wondering if i could use a gsr shifter in it instead of the civic one. if so, any special modifications need to be done to make it fit?
Old Aug 26, 2002 | 12:17 AM
Kamin's Avatar
Default Re: integra shifter in a civic? (Cat)
my buddy has one in his 99 coupe
no special mods that i know of, did you get the bushing with it?
its still slow tho
Old Aug 26, 2002 | 12:31 AM
eg6sir-s's Avatar
if you try putting a gsr aftermarket short shifter in your civic you might have some fitment problems(don't quote me on that) i have a sohc eg hatchback and currently using a dc2 gsr stock shifter modded to fit and the throws are shorter...saved me $80...if you want i have another one for sale for $40 direct bol-on...let me know
Old Aug 26, 2002 | 11:27 AM
.hugo's Avatar
Default Re: integra shifter in a civic? (KAMiN)
its still slow tho
haha, but yeah it should bolt rite up
Old Aug 26, 2002 | 11:54 AM
Thirty-Nine's Avatar
Default Re: integra shifter in a civic? (starang w0ndah)
According to my friend that has a GSR short shifter in his 97 LX, it will bolt right up, but it might rattle a bit, but it can be rigged not to rattle.
Old Aug 26, 2002 | 12:27 PM
SOSODef's Avatar
I have a Type R shifter in my ex coupe. Actually there are some mods u need to do. Considering the gsr is shorter throw than a stock civic, your shift linkage might rub against your exhaust pipe, like it did mine. I had to cut the hanger that keeps my exhaust pipe up to fit the shifter. The only problem is that the exhaust pipe scrapes every driveway I go over. Other than that, the shifter fits right in.
Old Aug 26, 2002 | 01:49 PM
Aaron M's Avatar
Default Re: integra shifter in a civic? (SOSODef)
I have a 2001 GS-R shifter for sell if anyone is intrested.
Old Aug 26, 2002 | 06:20 PM
redline201's Avatar
Default Re: integra shifter in a civic? (TYPE EG6)
is there a benifit for this ???
gsr shifter in a eg hatch with b16a
Old Aug 26, 2002 | 06:58 PM
allmtrSI's Avatar
if you put a gsr shift lever in a civic you have tpo cut the outer sleeve down to civic size and use the civic inner sleeve then it will work perfectly!
you cant just bolt one in the sleeve is alot wider on the gsr and you wouls have to bend the fork that it bolts into on the bottom
yeap, what he said... i came up on a gsr shifter and i wanted to put it in my '00 si but the damn thing was too thick.
Shaguar47
19
Jun 1, 2009 01:44 PM
BLUIZE256
Jan 21, 2007 09:53 AM
turnsignalandy
13
Apr 6, 2006 04:51 PM
GapxGuy
Oct 4, 2002 05:14 PM
baonest
May 10, 2002 12:50 AM
