iat sensor help?
well im trying to finish the swap and im having problems connecting the sensor my mechanic told me that it doesnt connect to the manifold and he said if this sensor isnt hooked up my car may run like crap
Your harness already has the sensor right??? You can drill a hole in your intake and plug it there. If not your OEM intake should have a hole.
You dont have to have it connected, your car will be fine but its recommended you have it installed. I drove around for 6 months without the sensor connected and it ran fine. The sensor could connect to either the manifold, or the intake.
ok so i dont have to extend the wire if i wanted to put the sensor in the intake instead of the manifold and wat do i do with the plug in the manifold since it will not be used ?
