distributor help? TIMING ISSUE? BOGGING?
I recently got my distributor replaced. when i got the ca rback the rpms were dancing around 3 grand. i noticed that the distributor was loose and not bolted to down that well it would move back and forth. i tightened the bolts down but no i was thinkin is the timing alil out of wack becuase i feel alil bit of bogging untill i get to 3000 rpm. how do i know if its in correct timing? what is the best way to make sure its all in time?PLEASE HELP i got a d16y5
Go back to the place that did the work and tell them what happened.
If it's a good shop they will fix their mistake.
All you need is a timing gun.
