H-T H22 rpm problem please help
Old Aug 20, 2009 | 11:04 AM
h22nick's Avatar
Default H-T H22 rpm problem please help
i have a 94 accord with a h swap im having a problem with the rpm tack its only reading up to 6,500... i have a chipted ecu at 8,000 rpm.. what could be helding it back??? thanks
Old Aug 20, 2009 | 11:13 AM
Luisito825's Avatar
Default Re: H-T H22 rpm problem please help
are you using a p13 ecu? is your vtec engaging at all?
Old Aug 20, 2009 | 05:09 PM
h22nick's Avatar
im not sure what ECU it is i think a converted P13,got from phearble.net and ya it pops at 4k
Old Aug 21, 2009 | 10:34 AM
h22nick's Avatar
What could the problem be??
Old Aug 21, 2009 | 01:12 PM
Luisito825's Avatar
i would get a regular usdm/jdm p13 and go from there. thats real low for it to be engaging btw.
are all your ground good? oil good?
Old Aug 21, 2009 | 04:47 PM
h22nick's Avatar
ya every thing is good and i told them to put it at 4k
Old Aug 21, 2009 | 09:02 PM
h22nick's Avatar
Could it be any thing else??
Old Aug 22, 2009 | 10:55 PM
h22nick's Avatar
i think its the gauge its reading rong how could i fix it??
Old Aug 22, 2009 | 11:40 PM
nus_dogg's Avatar
Either get a new one or remove the cluster and re-calibrate the rpm tech.
Old Aug 23, 2009 | 10:21 AM
h22nick's Avatar
How can u re-calibrate it?? What u need to do??
Old Aug 23, 2009 | 10:39 AM
street_ride14's Avatar
does the motor feel like it's pulling after 6500 or is that now it's redline ? My vote is for you to get the USDM virgin P13 ECU and see if that changes anything.
Why did you want a lower engagement of VTEC ? - your car did not even hit the dyno for a tune so that low of engagement screws everything up.
Old Aug 23, 2009 | 01:50 PM
h22nick's Avatar
Ya it's going past 6,500 cuz when I race my friend with same thing as I do we sift at same time and his car says 8,000 rpm
Old Aug 24, 2009 | 05:04 PM
h22nick's Avatar
Bump
Old Aug 25, 2009 | 09:02 PM
h22nick's Avatar
other sugestions??
Old Dec 7, 2009 | 11:16 AM
willbobh22's Avatar
hey i have a 95 accord with a h22 swap and the rpm doesnt read properly it will pull sweet till it gets to 5,000-5,500rpm then die off and if i run my car and try to pull 3rd gear the vtec cuts off any suggestions??
Old Dec 7, 2009 | 11:26 AM
willbobh22's Avatar
onenonly009
Aug 19, 2008 11:16 AM
JasonST
Jan 17, 2007 05:44 PM
MASTERTECH
May 13, 2005 10:10 PM
H22edAccord
Apr 18, 2004 05:29 PM
