I'm suffering in this heat!! Need AC Help!
Old Aug 20, 2009 | 07:48 AM
gqstatus05's Avatar
Default I'm suffering in this heat!! Need AC Help!
AC blows hot air from outside. I filled the AC and it blew cold for like a day then it went back to hot air. I know I have a leak somewhere. I have my soapy water spray bottle handy, where do I start spraying?
In the winter the heat in the car works flawlessly so like I said I'm guessing this is due to a leak somewhere. Can anyone post a diagram or picture of where I should be looking?
The car in question is a 96 Accord LX Auto
Old Aug 20, 2009 | 08:38 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: I'm suffering in this heat!! Need AC Help!
Just take it to one of the shops with the free diagnosis, then bounce once they locate your problem
But to answer your questions, start with the 2 lines and their connections in the engine bay running from the compressor to the firewall
Old Aug 20, 2009 | 09:21 AM
gqstatus05's Avatar
Ok. So should I crank up the AC to the max, spray it with soapy water to locate the air leak? Is this easily fixed. I don't think it's the compressor. What are the signs of a failing compressor? Thanks 213374U
Old Aug 20, 2009 | 09:32 AM
P_Adams's Avatar
The a/c system has refrigerant oil in it; and when it leaks it usually attracts dust and remains moist. I would look closely at the condenser (it's susceptible to impact damage and corrosion from the build up of organics (rotting leafs), at the front of the compressor (shaft seal leak), and check the pipes and hoses leading back to the evaporator case.
P
Old Aug 20, 2009 | 10:11 AM
gqstatus05's Avatar
Cool. I'm going to buy a Haynes Manual after work because everything you said just gave me a migraine. Thanks for the input P Adams.
Old Aug 20, 2009 | 11:31 AM
P_Adams's Avatar
LOL. I'm reminded periodically that I have that effect , but I've taken heart; at least you're willing to read.
P
dirtridernathan
Sep 15, 2013 11:12 AM
Revolver123
Honda Civic (2001 - 2005)
Jun 12, 2008 03:08 PM
92lsr
Oct 1, 2007 06:51 PM
GoLowDrew
May 10, 2002 09:38 AM
