Loud Noise and Egine Vibrating
Old Aug 19, 2009 | 11:08 PM
mhopkins10's Avatar
Icon3 Loud Noise and Egine Vibrating
I was driving my del sol and i was runnign pretty hard when all of sudden i heard a really loud whinny nose and then after slowing down the car started vibrating and i would give it some gas then it went away for a second but came right back so i pulled over and looked under the hood and the alternator belt was missing and the crankshaft pulley was loose like wobble loose. I am confused at what cause the problem i had it towed to my house and took off the pulley and the bolt that holds on the pulley was messed up on the threads at the end. I cant put the bolt on back on cause it doesnt go in straight it keeps wanting to go at an angle. I havent tried to start it again
Any advise would help thank you i really dont want to take it in i dont trust people working on my car. The engine is a D16Z6 car is 1993 honda del sol Si, i only have one belt on the pulley cause i dont have A/C or power steering in the car if you need anymore info let me know Thank Again
Old Aug 19, 2009 | 11:16 PM
Sleeperzzz95's Avatar
Default Re: Loud Noise and Egine Vibrating
Was the locking wedge thing on the pulley? if not it could have vibrated/backed out itself loose an went bad from there...
Old Aug 20, 2009 | 12:00 AM
blueEM1's Avatar
sounds to me like u might want to try a new bolt, if it still doesn't go in straight you might as well plan on needing a new crank, and poss. more depending on if anything is messed up internally
Old Aug 20, 2009 | 01:35 AM
-__-'s Avatar
^^what he said. if the timing belt slipped off any bit u probably have bent valves
Old Aug 20, 2009 | 01:59 AM
mhopkins10's Avatar
the locking wedge was not in there it was sitting inside the pulley when i pulled it off and the timming belt wasnt really loose just a little bit loose but not alot
Thanks
rushr
Oct 21, 2009 01:30 PM
Frost_1097
Jul 4, 2007 06:25 AM
pez1
Feb 16, 2006 07:41 PM
fatalman
Nov 13, 2005 06:43 PM
fatalman
Apr 8, 2005 12:19 PM
