Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
proper lifting/jack location for rear end
Old Aug 19, 2009 | 07:53 PM
Ben850's Avatar
Default proper lifting/jack location for rear end
hey guys, i know it's a dumb question but maybe it will save my life and the lives of others some day.
where is the proper lifting area for the rear end? i'll go ahead and guess that you place the jackstands under the lifting points by each wheel.
i've been doing some reading around, and people with different brand cars say that they lift with the rear tow hook.. is this ok for an 8th gen civic?
where is the proper location?
Old Aug 19, 2009 | 08:02 PM
FijiBlueFG2's Avatar
Road House
Default Re: proper lifting/jack location for rear end
How will you be lifting it?
Jack stands should go right before the rear tires.
If lifting with some sort of rope/cable, then sure tow hook is fine.
Old Aug 19, 2009 | 08:04 PM
Ben850's Avatar
sorry forgot to mention that!.. hydraulic jack
if i used a rope on the rear tow hook, wouldn't that screw up the bumper? lol
Old Aug 19, 2009 | 08:58 PM
RICO_'s Avatar
NO MERCY!
To get both back wheels up at the same time....Yes....you can use the rear tow hook. That f**ker is stronger than u think. I've done it a dozen times to make suspension adjustments.
Old Aug 19, 2009 | 10:18 PM
Nighthawk R18's Avatar
i usually do it from the rear lower tie bar. havnt died yet so.
Old Aug 19, 2009 | 10:26 PM
Ben850's Avatar
i'm no suspension guru.. but is this the part that the rear sway bar sits behind? (if looking at it from the back)
Old Aug 19, 2009 | 11:40 PM
K5^'s Avatar
K5^
Brand New
Like others have said, use the rear tow hook.
Old Aug 20, 2009 | 02:45 AM
Zeusone's Avatar
from the tow hook or where the center of the two rear lower control arms meet.
Old Aug 20, 2009 | 05:10 AM
k20amugensi's Avatar
tow hook by far. works like a charm
Old Aug 20, 2009 | 06:40 AM
2008fijibluesi's Avatar
I always jack on the frame that goes down the car...if you get it in the right spot you get both wheels (on one side) up at the same time and have plenty of room to place your jack stands.
I've seen a car fall off of a jack that was being jacked on the toe hook. Scared the bejesus out of me. The whole rear of the car shifted to the left like 3 feet as it fell and crushed a nearby jack stand under the rocker/quarter panel and dented the area of the car pretty badly. Luckily no one was hurt.
Old Aug 20, 2009 | 07:06 AM
HondaLoverQc's Avatar
Toe hook is safe if jack placed properly, but I always place jack stands just to get sure.
Old Aug 20, 2009 | 07:27 AM
i-VTEC_DOHC's Avatar
either the tow hook, the 2 jacking points in front of the rear tires, or the rear subframe where the lca bolts are.
jokerstone
Jan 6, 2015 08:16 PM
si90rex
Honda CR-V & Element
Sep 12, 2011 09:20 AM
RenoRacing
28
Nov 10, 2004 11:27 AM
KHowe
Sep 30, 2004 07:10 PM
