B16 Low Idle & Random Stall
Old Aug 19, 2009 | 04:12 PM
hondahatch91's Avatar
Default B16 Low Idle & Random Stall
Have a 91 crx s1 with swapped obdo b16a. Car has brand new tps sensor, MAP sensor, new throttle body, a fuel pressure regulator and brand new fuel filter. Problem has been on going since car was purchased any ideas on what it could be?
Old Aug 19, 2009 | 04:28 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: B16 Low Idle & Random Stall
Yeah you need to either set your idle screw/timing or you need to set the voltage for the TPS.
Old Aug 19, 2009 | 05:17 PM
Aftermarket throttle body no idle adjustment screw. TPS voltage is fine .45 and .50. Have also been told it could be the lack of a second o2 sensor that isn't present on the car. Has one on the exhaust is one also necessary on the headers?
Old Aug 19, 2009 | 05:51 PM
DO IT ON ALL FOURS
That won't make it die. It will just not run in closed loop. Also that must be some cheap *** throttle body if you can't adjust the idle RPM. Do it by the cable I guess...
Old Aug 19, 2009 | 07:56 PM
liquidrider's Avatar
unless you're running obd2 for some reason that's not going to be the problem. did you try changing or even cleaning the IACV?
Old Aug 20, 2009 | 07:01 AM
Yes has brand new IACV as well and have cleaned FICV as well and still nothing.
Old Aug 20, 2009 | 09:36 AM
raene's Avatar
Adjust the throttle stop for the butterfly if you have no idle adjustment screw.
But honestly, WTF kind of cheap TB has no idle adjustment screw... The Pro Products TB (which I have) is cheap and works well.
Old Aug 20, 2009 | 09:53 AM
thorclark's Avatar
I have this same exact problem i have a bdl 68mm throttle body. b16a converted obd1 changed the iacv 2 times. Someone told me it could be a air bubble in the coolant. Im going to try and bleed it out.
Old Aug 22, 2009 | 06:02 PM
thorclark's Avatar
anyone?
Old Aug 22, 2009 | 08:37 PM
camp_kill_yourself's Avatar
same problem 94 b16a in a 89 crx and idle will run fine then the idle will drop then pick back up and it will continue to do this for a while. I've tried the coolant thing but no results and Ive done all the things talked about in the early posts as well.
elli
Jun 1, 2010 01:22 PM
hondastrtracr
13
Jun 24, 2007 10:17 AM
snouka
Oct 15, 2004 02:02 PM
TheHatchHog
May 15, 2003 06:16 AM
cirionrc
Apr 27, 2002 10:47 AM
