Pre polished weld "L"s....
http://www.stainlesstubular.com/poli...s_fittings.htm
not sure if they have a minimum order amount but give them a call and then let us know what they say.
Not Hardly....not as much about being lazy as being more efficient.. I have a full time (60 hr /week) job and try to knock out 2 or 3 manifolds a week for a local speed shop that sells them mail order.. I will usually spend between 4/5 hours polishing the runners and collector on each manifold...with the 10/15 hours a week I spend just polishing ,I could get more manifolds finished if pre polished L's were available......
In for a source here. While I definitely am not willing to polish any, I did think of doing another manifold for my own car and I'd be willing to spend a little more to get a nice finished product.
Even if I could get some weld els that are worked in a tumbler to pretty them up. Wasn't AFI or someone doing that before finishing...maybe it was lovefab?
How many parts are we talking here? I may be willing to do them if theres a decent quantity.
i just purchased a tumbler from eastwood, put in some sched 10 90's in there overnight and they barely changed at all. tried several different media types and no luck. looks like i'll be returning the tumbler unless psi2hi can share what kinda media he uses etc.
Idk what kind of finish your after or what machine your using but if your looking for a polished finish its a multiple process ordeal. What we use here is a ceramic cutting media w/ a cleaner soap which will basically smooth the surface and leave a bit of a shine, then to a porcelian polishing media w/ a burnishing compound if you want a polished shine look. Its a timely process and like what i said earlier if your not doing quantity your not going to save yourself any time/money.
We can provide #4 finish (180 grit) straight lengths of pipe as well as tees, el's and 45's...however, they will be quite pricey compared to the standard mill finish fittings and pipe we stock. If there are enough people interested I'm sure we can get the price down a bit.
If anyone is interested let me know.
Personally, it wasn't something I wanted to do in terms of multiple pieces, just for my own personal project. Would be a nice option to have to really make something nice.
If you work 60 hours, and spend 4-5 hours polishing each manifold thens surely each manifold most take you 15 hours plus making a manifold, (5 to cut, 5 to weld) thats 105 hours working in a 168 hour week.
Personally I spend less time polishing than I do cutting/welding.
What polishing method do you use?
do u guys polish the pieces before u even start mocking them so u can just put them on a wheel? or do u tack everything up then takeapart then polish ? or what process exactly is the best u found.
all_motor_mike
Welding / Fabrication
Aug 18, 2010 09:10 PM
ChainbreakR
27
Feb 24, 2005 08:44 AM
