sway bar questions on 5th gen hatch
Old Aug 25, 2002 | 09:00 PM
chethewitt's Avatar
Default sway bar questions on 5th gen hatch
i have a sway bar from a 94 del sol si. now, if i can, should i install this sway bar on my 92dx hatchback?
thanks.
Old Aug 26, 2002 | 05:32 AM
BROOD's Avatar
Default Re: sway bar questions on 5th gen hatch (chethewitt)
Yes you can install it. Assuming you have the DelSol sway bar only you will still need some items.
~Some reinforcement kit Beaks or BSQ
~DelSol Vtec or GSR lower control arms (lca's)
~DelSol Vtec or GSR endlink assembiles (connects sway bar to lca's)
~DelSol Vtec or GSR D brackets (holds sway bar and D bushing to frame)
~DelSol Si D bushings (saied to match your sway bar diameter)
~the bolts to hold everything together
Old Aug 26, 2002 | 05:39 AM
BROOD's Avatar
Default Re: sway bar questions on 5th gen hatch (SLPR)
this may help.......
You have #5
You need:
~Some reinforcement kit Beaks or BSQ (search H-T for either kit)
~DelSol Vtec or GSR lower control arms (lca's) #16,18
~DelSol Vtec or GSR endlink assembiles (connects sway bar to lca's) #6,8,11,32,41,42
~DelSol Vtec or GSR D brackets (holds sway bar and D bushing to frame) #7,30
~DelSol Si D bushings (saied to match your sway bar diameter) #10
b18c1del
Feb 8, 2010 10:55 PM
civic89si666
Feb 16, 2009 05:59 PM
JMD
Jan 27, 2004 06:45 PM
LANL02
12
Aug 22, 2002 11:15 AM
