G23 build
Pretty much I've been researching "G23" engine builds (H22a4 head w/ F23a1 block) and I want to swap an H22a4 head on my F23a1 99' accord. Durring these other builds pretty much all of the components were taken from scratch and what my question is that since I already have the F23a1 will most of my stock components be compatible with the new head like the pulleys, belts, water pump, sensors and the ecu or am I going to need to swap some parts?
...but i would assume that anything on the block would stay on the block same for head but not sure have you checked out the import tuning magazine they have the complete swap step by step. Check out the website i think they have all info you need. Hit me up when you do the swap
And god created bananas...
Here
http://www.importtuner.com/tech/impp...dge/index.html
I said fk it and went with the TSX option. More efficient option in my oppinion. Im sure the additional attention would eventually equal a Kswap. And probably sooner than later
Here
Need H22 :
Head
Head gasket
Crank Timing gear
H22 water pump gear pressed onto F water pump
and some hondabond.
I have a head and crank gear available :O) CHEAP PM me
Head
Head gasket
Crank Timing gear
and some hondabond.
integral94
Jun 2, 2004 08:33 PM
