Transmission & Drivetrain Gearboxes, Differentials, Clutches
cable to hydro conversion
Old Aug 19, 2009 | 10:15 AM
hatchet_honda's Avatar
Default cable to hydro conversion
i have a hydro gsr trans in my 90 hatch with a b16a. well im using the hasport master cylinder adapter and the release sucks. anyone have better luck with a diff setup? i have a cable ls trans but that requires a new mount and diff clutch disc and rear bracket
Old Aug 19, 2009 | 10:48 AM
Hasport's Avatar
Default Re: cable to hydro conversion
what master cylinder are you using on the CMA?
Old Aug 19, 2009 | 01:02 PM
phunhaus's Avatar
https://honda-tech.com/forums/showth...ighlight=sonem
Old Aug 19, 2009 | 10:52 PM
oem honda master cylinder. maybe an aftermarket would work better?
Old Aug 19, 2009 | 10:56 PM
ive seen that lil bracket thing a few times....actually thought about it at first, havent even that setup used yet tho. id fab that bracket myself if i did go that route. dunno bout rippin out my vent tube and all
Old Aug 20, 2009 | 10:50 AM
brian g's Avatar
It shouldn't, there may be another problem. What is it doing, releasing too soon, too late?
brian g
Old Aug 20, 2009 | 08:05 PM
brian g
doesnt quite grab till the very top of the pedal....ive bled the line many times. big diff between driving my daily d15b with a cable trans and this hydraulic frankenstein in my b16 swap ef.
Old Aug 21, 2009 | 07:23 AM
brian g's Avatar
You should be able to adjust the cable now until you get the release right where you need it.
brian g
Old Aug 21, 2009 | 12:13 PM
bryse68's Avatar
i have the sonem setup in my crx with a hydro gsr, works great.....eliminates that POS cable completely......
Kid-jdm-teggy
Jul 8, 2013 07:01 PM
diamondstarsforever
35
Oct 11, 2010 01:15 AM
90Rexx
Sep 15, 2010 08:50 AM
dragDA
11
Mar 2, 2009 06:54 PM
stackz
Jul 30, 2007 07:45 AM
