honda's famous crank bolt
Old Aug 18, 2009 | 05:16 PM
Pure Sol's Avatar
Default honda's famous crank bolt
I've never had to fight this hard to get this bolt out. I've used every trick in the book, every tool of the trade and still it refuses to move one bit. I've even done better without the tool than with it, and now since I have it and am using it to do this job correctly one would think it would come out. Sorry just had to let off some steam, anyone care to add any tricks that I might have missed?
Old Aug 18, 2009 | 05:18 PM
nus_dogg's Avatar
Default Re: honda's famous crank bolt
Did you use the crank pulley tool to hold it in place while loosening the crank bolt?
Last thing I would do if this don't work is heat it up.
Old Aug 18, 2009 | 05:22 PM
Pure Sol's Avatar
done both
Old Aug 18, 2009 | 05:46 PM
fergs96integra's Avatar
Hit it with a gun forewards like for half a sec to a second. then reverse it out. Or you can always try a bigger gun with more torque.
Old Aug 18, 2009 | 07:49 PM
D_koschak's Avatar
take a set of torches and heat the bolt up till its cherry red (not a propane torch either) heat it cherry red wait till it turns black and heat it again till red and use an impact to get it off it will come super easy i have done it million times works everytime for me, and make sure u dont heat the pulley itself otherwise u will screw it up
Old Aug 18, 2009 | 08:05 PM
bow tie's Avatar
PB blaster? I'm still surprised the crank pulley tool didnt work for you. Usually that and a breaker bar always broke the nut for me.
Old Aug 18, 2009 | 08:15 PM
j3wman's Avatar
pb blaster and a impact gun
Old Aug 18, 2009 | 09:57 PM
CG6Accord8o1's Avatar
i swear u need a fcking long *** extention with a breaker bar.
Old Aug 18, 2009 | 10:02 PM
The-Kid's Avatar
I'm with CG6Accord8o1... Breaker bar with extension. It took me a 5 ft extension to get that thing loose. I only weight 155 lbs, but i could seriously lift myself up. It's crazy. Anyways, that should do the trick.
Old Aug 19, 2009 | 01:39 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
you can take it to your local mom and pop shop and they can loosen it for you and drive it home, if that makes any sense.
Old Aug 19, 2009 | 01:45 AM
YeuEmMaiMai's Avatar
^no to drive car home. I am 200lbs and a 5ft bar will do it for me
Old Aug 19, 2009 | 05:32 AM
Bird333's Avatar
This. I used about a 6 foot bar with the crank tool. You might need something in the neighborhood of 1200-1500 ft/lbs. Put enough torque on it and it will come off. Good luck
Old Aug 19, 2009 | 07:53 AM
213374U's Avatar
0x5359-0055
Community Builder
Yup, 3 FT breaker bar, crank pulley tool, and another 4 foot of aluminum cheater pipe.
Old Aug 19, 2009 | 12:00 PM
Mugen'dAccord's Avatar
yep thats exactly how i did it too
Old Aug 19, 2009 | 12:11 PM
monster_ls/vtec's Avatar
stick a rachet on it and give it a few hits like ur loosen it up with a nice size sledg hammer!! thats how i do it
barrera
Oct 11, 2010 07:17 AM
pjr710
Dec 30, 2008 06:11 PM
2kdrift
Aug 12, 2007 08:53 AM
MR_FIX_IT
Sep 23, 2006 04:01 PM
DaKINE-Ek
Aug 14, 2006 05:22 PM
