1996 Accord EX
Old Aug 18, 2009 | 03:45 PM
savage_al's Avatar
Default 1996 Accord EX
I was just wondering if anyone knows where I can find a diagram of the in dash fuse box (including relays) for a 96 Accord EX 2.2L. Or if anyone knows the part number for a starter cut relay for that model please let me know. I have been unable to start my car and when I tested it I am not getting power to the starter (smaller wire) but when I turn the key I am getting voltage through the starter fuse under the dash. Any ideas what else I should check?
Old Aug 18, 2009 | 03:53 PM
tamadrummer1120's Avatar
Default Re: 1996 Accord EX
Ok, good job getting the post up. Have you traced the starter wire? Made sure it did not ground out or anything like that?
Old Aug 19, 2009 | 10:05 AM
savage_al's Avatar
Yeah I traced it as far as I could and it looks good.
Old Aug 19, 2009 | 10:33 AM
P_Adams's Avatar
Manual Trans: Check the clutch starter over-ride switch
Auto Transmission: Neutral safety switch attached to shifter mechanism
P
Old Aug 19, 2009 | 11:10 AM
savage_al's Avatar
Where is it located?
savage_al's Avatar
(Clutch starter override switch)
Old Aug 19, 2009 | 11:23 AM
P_Adams's Avatar
It's attached to the clutch pedal hanger. The switch plunger interacts with the clutch pedal and doesn't allow the engine to crank until the pedal's depressed.
They often run afoul of someone's size 11 (triple wide), and go misadjusted
P
Old Aug 21, 2009 | 06:14 AM
savage_al's Avatar
The clutch starter over-ride switch is fine, unfortunately. Any other possibilities? I still havent been able to try checking the starter relay because I dont have a diagram or part # to find which one it is. Is that a good possibility or should I look eldewhere?
Old Aug 24, 2009 | 01:15 PM
savage_al's Avatar
Does anyone have the part # for the starter cut relay or a diagram of the under dash fuse panel (including the relays) Pleeeeeeeeeeeeeeaaaaaassseeee
Old Aug 24, 2009 | 01:54 PM
GhostAccord's Avatar
Icon6 1996 Accord EX Under Dash Fuse/relay Diagram
Not sure about the starter cut relay, never heard of it. The only relay involved in the starter wiring is the PGM-FI main relay. Other than that there is the brake check circuit and on automatic equipped vehicles there is also the A/T gear position switch.
Old Aug 25, 2009 | 05:00 PM
savage_al's Avatar
You rock. Thanks so much.
Old Aug 25, 2009 | 06:33 PM
NP Good luck!
DCFIVER
Honda Accord (2013 - 2015)
May 23, 2018 09:28 AM
Mason Edmison
Oct 22, 2017 09:19 AM
ndccpf1
Apr 14, 2013 05:58 PM
WarrenPeas
Feb 24, 2013 11:29 AM
Sleeper91
May 31, 2010 12:16 PM
