Adjusting Air Fuel Ratio On Throttle Body
Old Aug 18, 2009 | 02:41 PM
ekhatch66's Avatar
Default Adjusting Air Fuel Ratio On Throttle Body
Adjusting Air Fuel Ratio On Throttle Body B18b. Which way do you turn to richen it up? Which way do you turn to lean it out? Where is Factoring setting?
Old Aug 18, 2009 | 03:20 PM
Relic1's Avatar
Default Re: Adjusting Air Fuel Ratio On Throttle Body
the throttle body on a fuel injected engine has next to nothing to do with fuel. It adjusts air only.
if you're having fueling issues look else where.
if your idle is jumpy or too low check the IACV, located on the back of the IM.
Old Aug 18, 2009 | 03:32 PM
mtber's Avatar
Your throttle body does not control any kind of fuel. You have an electronic fuel injection vehicle...
Old Aug 19, 2009 | 09:14 AM
MONSTERek4's Avatar
well what you want to do is remove the throttle body completely and cap off the fuel return that way you get maximum air velocity and by capping off the fuel return it throw the perfect combo of air and fuel buddy
crxb16a90
Engine Management and Tuning
Jan 2, 2010 12:58 PM
adamsjm5
Nov 20, 2006 04:22 PM
Leviata-N
Sep 15, 2004 07:58 PM
R-Toyz.com
Jan 27, 2004 03:47 AM
Nikos
Sep 4, 2002 11:15 AM
