Need Help Please!!! B20/VTEC possible dropped valve
Old Aug 18, 2009 | 12:23 PM
jdm_sir2's Avatar
Default Need Help Please!!! B20/VTEC possible dropped valve
All right guys well i wanted to know what are the signs of a dropped valve on a motor???
This is what my car did last night and than this morning.
Last while driving home I was on 5th gear at 45mph at 2700rpm when I would go more than 30percent throttle i started to hear as knocking/rattling noise coming from the engine and it sound more from the head....after I get past maybe 3200rpm the sound went away.
This morning when going to work when i tried starting the car it took forever to get it to fire up alot more than the normal....once fired up the rpms were all jumpy and when I would flick the gas pedal to rev it up the rpm would drop to the point where the motor almost died...so i shut it off and resort to my second source of transport...
Is this a sign of a dropped valve?
Old Aug 18, 2009 | 12:45 PM
TorquelessEM1's Avatar
Default Re: Need Help Please!!! B20/VTEC possible dropped valve
Sure sounds like a bent/dropped valve to me. my k20 sounded just like this....
Old Aug 18, 2009 | 04:58 PM
jdm_sir2's Avatar
I'm sure there was no piston to valve contact so i'm going to tear it down starting today what are some things i should plan on replacing?
Old Aug 18, 2009 | 05:08 PM
00Red_SiR's Avatar
All Motor Mentor
Always start with the basics. Pull the spark plugs and have a look, they'll give you a pretty good idea as to what's going on in their respective cylinders. If any of them are physically damaged, it's a good indication that a valve has dropped (snapped off into the cylinder). Your timing belt could have jumped a couple teeth causing you to bend a valve(s), so if the plugs look ok, I'd perform a leak down test to see which cylinder(s) might be affected. Then I'd pull the head off and repair whatever damage I had to.
Old Aug 18, 2009 | 05:13 PM
jdm_sir2's Avatar
Well i pulled the plugs out already they look really clean the only thing is that the insulator is kinda a reddish of color so i'm not sure if it fuel related or timing related or maybe just a bit of both...and i checked the timing and it's still right on the money...crank pulley lines up with the mark and so does my cam gears...
Old Aug 18, 2009 | 05:19 PM
00Red_SiR's Avatar
All Motor Mentor
Have a leak down test or at the very least, a compression test done to see how the cylinder sealing is.
Old Aug 18, 2009 | 05:31 PM
jdm_sir2's Avatar
Should i crank it over I mean i don't want to mess anything up beyond repair you know what i mean? I just wan't to make sure i'm not going to scare my block or bust a whole through a piston...what are some other methods?
Old Aug 18, 2009 | 05:52 PM
DDTECH's Avatar
rod knock.
Old Aug 18, 2009 | 05:58 PM
00Red_SiR's Avatar
All Motor Mentor
You've already cranked over the engine and driven it so I doubt cranking it over to do a test will affect much at this point. It does sound like it could be rod knock.
Old Aug 18, 2009 | 06:02 PM
PyroProblem's Avatar
This is NOT the sign of a dropped valve. Dropped valves will make HORRIBLE HORRIBLE sounds and usually lock up the engine... This is the sound of audible detonation aka knock...
Did you recently fill up on gas by chance?
Old Aug 18, 2009 | 06:44 PM
DDTECH's Avatar
you can't mistake rod knock.. specially at a certain rpm
if you dropped a valve your car wouldn't run.. and if it did, it wouldn't last long i promise.. trust me.
Old Aug 18, 2009 | 08:16 PM
jdm_sir2's Avatar
It's not rod knock that is one sound i can recognize right away it sounds more like a clanking/rattling like when you have a rocker thats completely loose....did a compression check i had:
1- 233psi
2- 235psi
3- 235psi
4- 225psi
There was no pressure drop at all everything stayed with no leakage....
Old Aug 18, 2009 | 09:45 PM
UncleD's Avatar
Dude - if you drop a valve, you're done. You're on the side of the road with a car not running. Simple as that.
Old Aug 18, 2009 | 10:02 PM
jdm_sir2's Avatar
Yeah i'm starting to wonder what else it could be i'm going to unbolt the valve train and recheck it see if something is loose and see what it does again.....cuz the noise is coming from the head no the block and usually if i had rod knock u can really hear it on a cold start up
Old Aug 18, 2009 | 11:11 PM
big_daddy234's Avatar
with compression like that i doubt you've dropped a valve
Old Aug 19, 2009 | 03:58 AM
DDTECH's Avatar
rod knock.
drain your oil or pull your valvecover.. tell me if theirs metal shavings everywhere.
This isn't my first rodeo bro.. i'm just trying to help you..
A dropped valve would have destoried your motor.. you might have a stuck lms, but that wouldn't cause a "clacking noise"
Old Aug 19, 2009 | 07:29 AM
jayWknight's Avatar
what type of fuel management are you using?
Old Aug 19, 2009 | 07:59 AM
jdm_sir2's Avatar
Chipped p28/ Hondata S200 and 440cc injector, 255lph fuel pump, B&M Fuel pressure regulator and fuel pressure gauge. I made sure not to skimp out on the fuel system when i first starting building this motor....
Well I drained the oil last night i only had 250miles on that oil and it didn't have any metal shaving came out clean even my magnetic drain plug had no shavings. The oil did look a bit darker for only 250 miles of driving. Checked around the motor for any no leaks, i also decided to drain my radiator and check the antifreeze it's clean so i'm honestly stumped right now... When i built the motor I had the crank balanced and micropolished, block was honed,decked, hot tanked. I measured everything before the machining than after the machining and before the assembly and I was well within the factory spec not even close to the service limits.It's not the first motor ive built but i've never had this problem this is completely a first for me...
Old Aug 19, 2009 | 08:07 AM
jdm_sir2's Avatar
rod knock.
I was searching around and there was a thread somewhere mentioning similar symptoms. The head is off a 99 Si and the dude I got it from said that the valve stem seals were only a few hundred miles old but he was full of sh*t. I did get the head inspected when i first bought but fail to change the valve stem seals running off the seller info...anyways the thread i read had some guy on start up have the similar noise come from the head and he said when he pulled the head apart the when he pushed down on the LMS it would stay stuck down and he would have to actually pull it up. And like i mentioned it really sound like a rocker is loose and flapping around i mean this head is 10yrs i'm just going to see what some updating will do...
Old Aug 19, 2009 | 07:34 PM
Does it sound like pebbles being shaken in an empty coffee can?
Can you make the sound happen with the car not moving (no load)?
Old Aug 31, 2009 | 07:57 AM
imsickofrice's Avatar
in for the answer.
Old Aug 31, 2009 | 06:39 PM
kingofbattle909's Avatar
me2
Old Aug 31, 2009 | 08:30 PM
jdm_sir2's Avatar
double checked everything and took the car for a retune first guy that tuned it had to much timing and the car was pinging really really bad... been driving it for a week already and it running really strong going to be pulling the head off pretty soon to install new style LMA and upgrade the valve train to get it ready to retune with BC Spec 3+ cams...
ki0326
Engine Management and Tuning
May 29, 2012 10:43 PM
hbboostman
Jun 11, 2007 04:03 PM
hgem1si
Apr 3, 2007 08:53 AM
Fatty_1775
Apr 16, 2005 02:38 PM
HONDA_TYPE_R
Nov 3, 2004 08:17 AM
