f18b2 engine to which US honda i can compare it with ?
Old Aug 18, 2009 | 02:51 AM
mvk1982's Avatar
Default f18b2 engine to which US honda i can compare it with ?
hey guys,
i got al little problem i have owned a few honda's now
a couple of crx's and an integra type R
but then came the kids and blabalbalablaba....
now i own a 99 honda accord 4 door sedan and was looking for some
upgrades only the problem is that the accord that i have here in europe/holland does not exist in U.S can you help me out with maybe telling
me what US honda i can compare it to for maybe cams/pulleys/intake's exhaust and eventually turbo's etc etc etc.
it is a honda accord model range from 98/99 to 2001/02
it is a 1.8L SOHC Vtec (1849cc/100Kw)
engine code F18B2 yes F18B2
the type i'm not sure of indetification plate says CG8 ???
manual transmission
PLease help me out thanx.
Old Aug 18, 2009 | 03:09 AM
hondamark35's Avatar
Default Re: f18b2 engine to which US honda i can compare it with ?
i've never seen one in person, but i saw these pics.. http://www.**********.com/general-te...use-f18b2.html (must insert "one cam only" w/o spaces to view link.)
it looks a lot like the F23A1 head from the USDM Accord EX. my guess is the block is similar, maybe just destroked to 1.8L..?
Old Aug 18, 2009 | 03:23 AM
mvk1982's Avatar
thanx that's something already i hope some more people have suggestions
thank you
Old Aug 18, 2009 | 11:20 AM
Boosted-Ego's Avatar
You could possible use the F20B head but dont hold me to it. Im not 100% for sure.
Old Aug 18, 2009 | 11:51 AM
nus_dogg's Avatar
yeah, I'd compare it with the F23A1 which puts out 150hp at the crank as the F18B.
Old Aug 18, 2009 | 01:53 PM
i've read it has the 85mm bore like the F22's (where as the F23 has 86mm) and a 81mm stroke (which is pretty small!) assuming it has a 30mm compression height like most do, it should have a super revy 1.85 Rod/Stroke ratio!!!
might be a good motor for ITB's and upgraded valvetrain N/A build...
Old Aug 20, 2009 | 06:52 AM
mvk1982's Avatar
Specifications
Bore × Stroke: 85.0 × 81.0 mm
Displacement: 1849 cc
Valve Configuration: SOHC, 16 valves, VTEC
Compression ratio: 9.3:1
Max power: 138PS (103 kW)
Max torque: 124 ft·lbf (165 N m)
maybe this will help ???
so for example if i needed some headers for this engine what should i order
in US for the F22 F23 ??? engine ????
Old Aug 20, 2009 | 07:08 AM
GhostAccord's Avatar
Can you check what numbers are cast on the head? Could be P0A, P0B or something similar. That way we can tell you what USDM valve train, intake & exhaust will bolt up. If I had to guess I would say that it is similar to a SOHC F22B head. But it could be an F22A*
Head Cast Numbers
90-93
PT3 = SOHC Non VTEC (F22A*)
94-97
P0B = SOHC Non VTEC (USDM F22B2)
P0A = SOHC VTEC (USDM F22B1)
Old Aug 20, 2009 | 10:25 AM
mvk1982's Avatar
right above the heat shield for the manifold/headers
it say's PDA-HU-1 is that possible ?? or is that the wrong number ?
thank you for you're help
Oh and by the way it's a vtec only a sohc !?
Old Aug 20, 2009 | 11:29 AM
If I had to guess then I would say that your PDA head is most like a P0A (F22B1 Accord EX (EX-R Canada)
Old Aug 20, 2009 | 11:51 AM
mvk1982's Avatar
okay thank you but what must i do in order to know for sure..
if for example i want to fit throttle boddy or cam or header or exhauts
or anything for that mather for which engine/model
i need to order parts is there anyway to know for sure ?
i guess a f22 is a 2.2L so cams for that engine would not fit my accord...
do i have to take off the valve cover and make pictures ? or take some measurements (god knows how ?)
there are so much aftermarket parts for the us engine's (what is understandable) the only problem is when i order and it doesn't fit then i have spend $$$$$ for shi*.
thanx again
Cain951
Sep 22, 2016 01:28 PM
Xavier Davis
Jul 31, 2015 04:28 PM
Donboss
Sep 27, 2006 11:10 AM
Anderson
Mar 19, 2003 11:36 AM
