Built z6 head, also stock z6 head
Old Aug 17, 2009 | 10:38 PM
fltblkEFhatch's Avatar
Default Built z6 head, also stock z6 head
well...my plans have changed again (im an indecisive bastard) so im selling my head that i had finished for my project
ima keep this short-n-sweet
-zex single valve springs
-zex aluminium retainers
-zex cam
-skunk2 adjustable cam gear
- ported
-ferea oem size valves
will come with stock z6 intake manifold, new valve seals (extra, the ones in the head are still good, but i have them so why not?) good looking valve cover, and i have plenty more single cam parts so let me know what you want
im asking 350 OBO for the built head
also i have a stock z6 head perfect running condition that is still on my old engine (i had bad rings on the engine, but i wasn't smoking, i just had low compression on a few cylinders) both heads have fresh valve-lash done and are ready to go...im asking 100 obo for the stock head...will also come with a valve cover (but it's not the prettiest one)
PM ME IF INTERESTED PLEASE AND PLEASE BUMP IF VIEWED
Old Aug 17, 2009 | 10:47 PM
JDM_Frijoles's Avatar
Default Re: Built z6 head, also stock z6 head
Bump for a good guy!
Old Aug 17, 2009 | 10:48 PM
da_dude's Avatar
Get some pics of the ported head up. It will help the sales.
Old Aug 18, 2009 | 08:22 AM
good thinking...and thanks for the bump chano ::....i still have to pull the stock head off the block to to comparison pictures, but it will be done today...
Old Aug 18, 2009 | 02:42 PM
Jimster480's Avatar
can i see some pics of the built head?
what kind of cam is in there? how aggressive is it? is it a turbo or NA based cam?
Old Aug 18, 2009 | 11:06 PM
crxses's Avatar
I'll take the stock head. I want to make my D15 slightly more exciting.
Old Aug 19, 2009 | 11:09 AM
built head
Old Aug 19, 2009 | 02:18 PM
Jimster480's Avatar
very nice head. How much is it ported? After school starts i'll see how much money i make/have leftover maybe i can pick it up.
Old Aug 19, 2009 | 02:29 PM
i pm'ed you jimster..........
i also have srp lowcomp. pistons/rings, eagle h-beams (the pistons and rods need machine work) and arp rod bolts/head studs for a good price so let me know anybody
Old Aug 19, 2009 | 02:52 PM
Jimster480's Avatar
ya i have a Built bottom end already. YCP STD Vitara's SCAT Forged H-Beam Rods, Klevite Bearings, Weighted and Balanced Rotating assembly. its running on a stock Z6 head on a Y8 block. Put down ~270WHP @ 13PSI. If it pick it up it will be for the winter when im going to turn the boost up and get it retuned.
Old Aug 19, 2009 | 08:03 PM
nice...i would also recomend putting the redline slightly higher on the new tune...because with the valve train, cam and the port, you will be putting down some damn good numbers between 7-9k rpm...just a thought...and with the springs and retainers the head is built to handle up to 11k rpm....(my buddy actually had a d15b with a similar setup revving up to 13k) and the head outlasted the bottom end...
Old Aug 19, 2009 | 08:24 PM
Jimster480's Avatar
thats what will happen. The bottom end will go. It just doesnt have a good R/S Ratio and it will eat up the rings, also the Y8 crank only has 1 Oiling Port per Bearing instead of 2 on the A6 and Z6. So it has a tendency to spin bearings @ high RPM. if I wanted to take it up that high I would have to get the crank drilled and knife edged. My Redline is 7400 right now and its gonna stay like that. Maybe I would increase it to 8k but no more than that without work done on the crank or the motor will die an early death. And its my DD so :/
My friend had a FULLY BUILT Y5, SK2 IM/TB SK2 Cams & Valvetrain, Wiseco 9.0CR Forged Pistons, Eagle H Beam Rods, Klevite Bearings, Knife Edged Crank, Fully Weighted and Balanced, ARP Bolts on Everything, Y8 Tranny. Boosting 7-12PSI (idk what turbo it was). 255lph Fuel Pump, 450cc Injectors, etc. Tuned on Chrome. He used to take it to like 8500 and he spun a bearing in a few months of doing that.
Old Aug 20, 2009 | 08:06 PM
bump
Old Aug 21, 2009 | 02:10 PM
top then down to the pics
Old Sep 7, 2009 | 07:37 AM
thierry's Avatar
what other parts do you have for single cam?
Old Nov 7, 2009 | 05:00 AM
peruboy33's Avatar
New User
are you still selling the built z6 head?
9hatchturbo5
Feb 1, 2013 03:20 PM
jfrase06
Apr 20, 2007 04:42 AM
I-Am-Chris
Jul 22, 2002 01:07 PM
